11-01-2009, 8:51 PM
#1 (permalink)
| | Member
Thanks: Gave 8, Got 6 | Transfer iPhone to another machine
I currently sync my iPhone with my laptop but would like to start doing this on my desktop machine instead, how would I go about doing that?
Do you just sync with the desktop or is there further steps involved? My iPhone is jailbroken don't know if that makes a difference.
13-01-2009, 7:34 AM
#2 (permalink)
| | Member
Thanks: Gave 8, Got 6 | Re: Transfer iPhone to another machine
Anyone?
13-01-2009, 7:53 AM
#3 (permalink)
| | Moderator
Thanks: Gave 143, Got 540 | Re: Transfer iPhone to another machine
Does the desktop have all your contacts, etc on it?
If it doesnt then I believe all your contacts, music, photos, etc. will get wiped when you sync to your new machine.
__________________ PS3 Gamertag: ianhutch1 XBox360 Gamertag: hutch My opinions expressed here are my own and do not necessarily represent those of the AV Forums or associated websites.
13-01-2009, 9:27 AM
#4 (permalink)
| | Member
Thanks: Gave 8, Got 6 | Re: Transfer iPhone to another machine Quote:
Originally Posted by hutch Does the desktop have all your contacts, etc on it?
If it doesnt then I believe all your contacts, music, photos, etc. will get wiped when you sync to your new machine. | No the desktop just has a new installation of iTunes, is there away to get contacts etc synched from the laptop or iPhone to the desktop?
13-01-2009, 9:38 AM
#5 (permalink)
| | Member
Thanks: Gave 23, Got 17 | Re: Transfer iPhone to another machine
I'm not expert, but can you not just back-up your itunes and contacts on your laptop and put them on your pc, then you can sync to that?
Panasonic 42PX80 / Sky HD / Sony HTSF1000 / xbox 360 / harmony 525 / iPhone 3G 16GB
xbox live gamertag: Shatners Basoon
13-01-2009, 10:33 AM
#6 (permalink)
| | Veteran Member
Thanks: Gave 124, Got 468 | Re: Transfer iPhone to another machine
Recently did this myself.
Copied the whole iTunes directory onto an external HDD and then copied it again onto the new PC.
Hey presto. The computer will give you the blurb about your account on a new pc, but thats about it. Simple.
__________________ Sony Bravia 52W5500 / XBox 360 Elite & Arcade / PS3 60GB / Logitech Harmony 555 / Sky+ HD / Sony STR DG820 / Bowers & Wilkins 601 S2 & CC6 S2 / KEF 1005's ... and a subwoofer with an Ikea cushion on it for a seat! |
13-01-2009, 11:30 AM
#7 (permalink)
| | Member
Hey presto. The computer will give you the blurb about your account on a new pc, but thats about it. Simple.  | Thats great I will give this a go myself, so you just installed iTunes on your new machine and copied the whole directory from your old machine and overwritten everything.
13-01-2009, 12:28 PM
#8 (permalink)
| | Senior Member
Thanks: Gave 55, Got 122 | Re: Transfer iPhone to another machine
Stupid piece of software it shouldn't be deleting anything unless you tell it too !
Panasonic TH46PZ80BA : Humax Foxsat HDR : Panasonic DMR EX75 : Playstation PS3 : Harman Kardon AVR505Le : Harman Kardon HD 755 CD : Monitor Audio BR5s.
15-01-2009, 11:43 AM
#9 (permalink)
| | Member
Hey presto. The computer will give you the blurb about your account on a new pc, but thats about it. Simple.  | I installed iTunes on my new PC and copied the directory from my laptop to the PC and plugged in my iPhone and it never asked me anything just recognised my iPhone usually doing a sync takes a bit of time but within a few seconds it syncs?
Have I done this right and it also keeps saying it cannot find Outlook to sync with?
15-01-2009, 12:27 PM
#10 (permalink)
| | Member
Thanks: Gave 29, Got 1 | Re: Transfer iPhone to another machine
Is it not safer to just manually manage your music rather than sync it?
If you manually manage, can you install apps?
15-01-2009, 1:23 PM
#11 (permalink)
| | Senior Member
Thanks: Gave 59, Got 313 | Re: Transfer iPhone to another machine Quote:
Originally Posted by _s79 Is it not safer to just manually manage your music rather than sync it?
If you manually manage, can you install apps? | yes you can...i manually manage everything and only sync my photos WHEN i want to. you can still install apps.
__________________ Apple iPhone 3G | Apple Macbook | Canon Ixus 65 | Canon EOS 450D | Panasonic TX-32LXD500 | Sony HDR-SR11 | Sony PSP | Sony PS3 Flickr |
15-01-2009, 2:37 PM
#12 (permalink)
| | Prominent Member
Thanks: Gave 138, Got 259 | Re: Transfer iPhone to another machine
How would this work if you were moving from a Windows desktop to a Mac?
__________________ Samsung PS50A558 | Sony DVP-NS92V | Sony STR-DB870 | Mission M74, M7DS, AS6e | DUAL Freeview PVR | BUSH Freesat HD | Compaq D510 "Ghetto" HTPC | iPod Classic 80gb | iPhone 3G 16GB |
15-01-2009, 2:56 PM
#13 (permalink)
| | Member
Thanks: Gave 107, Got 62 | Re: Transfer iPhone to another machine Quote:
Originally Posted by Matt_C How would this work if you were moving from a Windows desktop to a Mac? | I'm wondering that myself after getting an imac
Sony 40V4000 ¦ Sony HTD-DW880 ¦ Marantz 6600 ¦ SKY HD ¦ Harmony One ¦ PS3 60gb ¦
15-01-2009, 5:19 PM
#14 (permalink)
| | Senior Member
Thanks: Gave 28, Got 78 | Re: Transfer iPhone to another machine
You will have no problem moving to a mac at all.
To avoid sync issues when moving from computer to computer (or just on the one) in itunes go into preferences - devices and then disable the autosync option. It will never do it again and you can make sure you only sync (and delete) what you intend to.
Regards Gary
The Spaniard
15-01-2009, 5:23 PM
#15 (permalink)
| | Member
What is the best method transferring iTunes from one computer to another for the iPhone?
I have tried the above method of just copying the iTunes directory over and it does not sync or backup and does not recognise any applications on my phone.
