Originally Posted by hutch. Have you tried it outside or just inside? |
Both. I know the GPS won't work in doors but I tried anyway to see if it would work with WiFi which it sort of did but I wasn't in the sea somewhere near Canada which it somehow thinks I am there.
Originally Posted by davemulheran how are you guys testing the GPS? |
Lots of different ways.
Firstly I tried several different locations near where I live. Including vast open areas such as fields and lakes (no trees or buildings blocking any view to the sky), built up city centres (again tried to find a spot close to the sky), outside my home in my garden and in a car on an A road. I also tried these locations with a TomTom 520 and the TomTom spotted my location within a few seconds.
I also tried several different setting like having 3G on and off and WiFi on and off.
I tested with different firmware (if you do a restore in iTunes the version number goes up from 2.0 (5A345) to 2.0 (5A347)).
I tried resetting the network and carrier settings.
I made sure that the date/time and international settings were correct for the UK (according to Apple these need to be correct otherwise when it tries to compare times with the sats/servers and they are vastly off it won't work).
I have turned off all radios and tried and then just turned on location services.
I have tested the mapping service with different radio and internet technologies in different locations including 3G (didn't work), EDGE (did work however again it said I was in the sea near Canada also it was extremely slow), my home WiFi (using an AirPort Extreme Base Station and a BT HomeHub and again did work however again it said I was in the sea near Canada) and using 3G (didn't work).
I am not sure what else to try. I have had several phone calls with level 1 and 2 app reps and had an appointment with the guys at the Genius bar at the Apple Store in Milton Keynes and still have had no luck getting it working.
The only application I am using to spot my location is Google Maps and I am clicking the button on the bottom left hand corner which looks like a cross hair. Also I am not trying to get turn by turn directions (as I aware that's currently not possible) but I would like a marker to spot where I am. Most of the time when it tries to find where I am the icon in the bottom left just spins around for ages and most of the time keeps spinning well after the screen has turned itself off.
Anyone have any ideas for things I could try?
