Originally Posted by coffe break Ash,
I had exactly the same problem with mine. It turned out to be a years worth of pocket fluff / tissue that had made it's way into the socket. You couldn't really see anything but I stuck a pin in the socket and was amazed what I fished out.
Got to be worth a go!
Simon |
Ditto the above, my headphones would only go so far into the socket, giving me just sound out of one ear piece, and no control using the little button on the lead.
I used a paperclip and pulled out ALOT of pocket fluff also. If you hold it up in the light at the right angle, I bet you can see a bed of fluff, that you've nicely compressed down attempting to push in your headphones further
