03-11-2009, 6:17 PM
#1 (permalink)
| | Member
Thanks: Gave 58, Got 26 | Anyone having trouble with Wifi connection?
For the past 2 days my wifi is not connecting and it also keeps asking me for a password. This is the first time it's started to do this, as I set it up without any problems when I first got the phone
In wifi networks it can see the router, and when I 'tick' that network it tries to connect, but no ip address comes up...after a few mins a box appears to tell me the password is incorrect. I have re-input the password/s (tried them all) but its no deal
I have deleted the network and tried to get it to pick the network up again, but its all in vein
Can anyone give me a clue where I'm going wrong, as I've googled the problem and quite a few people are having some problems or another...don't know if it's something to do with software version 3.1.2
I have used blackra1n to jailbreak
03-11-2009, 6:52 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 335, Got 166 | Re: Anyone having trouble with Wifi connection?
I often lost wifi connection - only way to fix was a modem router reset. Didn't know if it was my Netgear or Iphone.
In the end I assigned the Iphone a static ip and never had a problem since.
04-11-2009, 8:59 PM
#3 (permalink)
| | Member
Thanks: Gave 58, Got 26 | Re: Anyone having trouble with Wifi connection?
Right, I've restored my iPhone back to 'normal' still no wifi icon or connection, so have booked an appointment at the Genius Bar on Saturday morning
Do I need to take any documents ie: purchase invoice etc.
04-11-2009, 10:22 PM
#4 (permalink)
| | Member
Thanks: Gave 37, Got 60 | Re: Anyone having trouble with Wifi connection?
my iphone 3g wifi has just stopped working, it just says No Wi-Fi and this is greyed out?? tried a master reset and reset network settings, still nothing. anyone else had this problem or know of a solution?
We Are Evil |
04-11-2009, 10:46 PM
#5 (permalink)
| | Member
Thanks: Gave 58, Got 26 | Re: Anyone having trouble with Wifi connection? Quote:
Originally Posted by snellfish my iphone 3g wifi has just stopped working, it just says No Wi-Fi and this is greyed out?? tried a master reset and reset network settings, still nothing. anyone else had this problem or know of a solution? | Mines not greyed out, but if you google it there are lot of posts from about July onwards about it
05-11-2009, 9:28 AM
#6 (permalink)
| | Member
Thanks: Gave 37, Got 60 | Re: Anyone having trouble with Wifi connection? Quote:
Originally Posted by SourKraut Mines not greyed out, but if you google it there are lot of posts from about July onwards about it | i know i just thought someone on here may have fixed the problem, shall i start up a new thread with my problem (mods)?
We Are Evil |
05-11-2009, 9:57 AM
#7 (permalink)
| | Member
Thanks: Gave 4, Got 10 | Re: Anyone having trouble with Wifi connection?
Go to settings, general, reset, & then click reset network settings takes about 5 minutes
05-11-2009, 10:18 AM
#8 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: Anyone having trouble with Wifi connection? Ever since the upgrade to 3.1.2, I also have the same problem. Sometimes I need to reset the network settings a few times before getting the wifi connection back. Quote:
Originally Posted by panjabi_j4tt Go to settings, general, reset, & then click reset network settings takes about 5 minutes | |
05-11-2009, 10:31 AM
#9 (permalink)
| | Member
Thanks: Gave 35, Got 10 | Re: Anyone having trouble with Wifi connection?
I am once again having wifi problems. Mine was previously set to DCHP and would only connect occasionaly in spite of finding my wireless network all the time, i solved this by setting a static ip address and this worked perfectly till the last few days. For no apparent reason i now get the unable to connect message. My computer and iphone settings are shown below
PSN: devil1916
Games Call of Duty 4, Singstar, Tiger woods 2008, Fifa 2008, Rainbow 6 Vegas.
05-11-2009, 10:32 AM
#10 (permalink)
| | Member
I would suggest doing a full restore in itunes and then use the latest blackra1n which should say RC3 once downloaded. My wifi was fine when i used blakra1n before but when i did the unlock last night it went off completely. So i did a full restore, did blackra1n again but i still had no wifi, proceeded to do the steps above and it worked.
05-11-2009, 7:16 PM
#12 (permalink)
| | Member
Originally Posted by panjabi_j4tt Go to settings, general, reset, & then click reset network settings takes about 5 minutes | I've tried that too without success |
05-11-2009, 7:34 PM
#13 (permalink)
| | Member
I've just done another restore, but this time have setup the iphone as a new phone, and guess what.................I have my wifi back...just put in the password and I now have the wifi icon and I'm able to surf the net again, but for how long is another question
Edit: I have restored to a backup from yesterday, and my wifi is still working, so I will try jailbreaking now and get my themes back
Reason: update
06-11-2009, 7:08 PM
#14 (permalink)
| | Member
Thanks: Gave 35, Got 10 | Re: Anyone having trouble with Wifi connection? Quote:
Originally Posted by devil1916 I am once again having wifi problems. Mine was previously set to DCHP and would only connect occasionaly in spite of finding my wireless network all the time, i solved this by setting a static ip address and this worked perfectly till the last few days. For no apparent reason i now get the unable to connect message. My computer and iphone settings are shown below | I tired reseting and did a full restore setting up as a new phone and tried wife before and after jailbreaking and although it finds my network straight away i still get the unable to join message
PSN: devil1916
