30-10-2009, 3:10 PM
#1 (permalink)
| | Prominent Member
Thanks: Gave 249, Got 444 | Brodit iPhone holder - will the standard one take iPhone in a Incipio Feather case?
Or will i need to go for the adjustable model?
Cheers, Auto. Lounge: Panasonic P37X10, Topfield 5810 PVR, Philips BDP3000, Squeezebox 3, Harmony One, Cambridge Audio 640A, Mission 701's Kitchen: Squeezebox Touch, Trends TA-10.1, Kef Cresta 1's. Bedroom: Squeezebox Boom Bathroom: Squeezebox Radio Car: iPod Classic 80Gb Portable: iPhone 3GS 32Gb |
30-10-2009, 4:02 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 64, Got 270 | Re: Brodit iPhone holder - will the standard one take iPhone in a Incipio Feather cas
Not sure, but I bought the adjustable model as it was the same price as the standard one. £20.50 from Morpeth Mobiles
The adjustable one has 4 thumbscrews on the back so is easily changed. The only thing I'd say that would make it worse than the standard one is that it has also been "carved" for thicker cases so the feather does rock back under pressure but then just stays there. I'm more than happy with it though |
30-10-2009, 5:31 PM
#3 (permalink)
| | Member
Thanks: Gave 6, Got 8 | Re: Brodit iPhone holder - will the standard one take iPhone in a Incipio Feather cas Quote:
Originally Posted by Autopilot Or will i need to go for the adjustable model? | If you but it can you let me know if it fits? I have the brodit swivel holder and am just waiting on the clip, am also considering buying the incipio feather.
Brodit mount is awesome by the way |
30-10-2009, 6:50 PM
#4 (permalink)
| | Prominent Member
Thanks: Gave 249, Got 444 | Re: Brodit iPhone holder - will the standard one take iPhone in a Incipio Feather cas Quote:
Originally Posted by robodan If you but it can you let me know if it fits? I have the brodit swivel holder and am just waiting on the clip, am also considering buying the incipio feather.
Brodit mount is awesome by the way  | Well I would just get the adjustable one but with pass through connector the cheapest I can find it is £42. Plus the proclip and delivery, i'm looking £60.
Anyone know where the cheapest place to buy brodit stuff is?
31-10-2009, 8:12 PM
#5 (permalink)
| | Moderator
Thanks: Gave 155, Got 561 | Re: Brodit iPhone holder - will the standard one take iPhone in a Incipio Feather cas
I've been looking around for some time for a passthrough Brodit and Pro Clip and they are a similar price wherever you find them. Post back here if you find a bargain though.
03-11-2009, 12:46 PM
#6 (permalink)
| | Prominent Member
Quick update for anyone interested.
I received my Brodit today and had it fitted in 5 mins. And yes, if you have an Incipio Feather case you do need the adjustable type. Because the Feather is so slim, and the Adjustable Brodit is designed to take cases of all sizes, it does rock very slightly but does not move in use. However this is not a problem because the Active model clicks into the dock connector and this helps hold it steady. Non-active Brodits might rock a little bit in use with cases as thin as the Feather, but i dont think its really going to be an issue. You can also tighten them up to prevent this, but its not so easy to drop the iPhone in and needs more of a push, i guess it personal preference.
I am over the moon with it, coupled with THIS cable it really is the dogs danglies.
I got mine from DSL Developments as they take Paypal and i had the money in my Paypal account. However the cheapest i have found is a seller on Amazon Marketplace called 'The_Mount_Shop' (although the actual Proclip was slightly more expensive).
03-11-2009, 5:56 PM
#7 (permalink)
| | Senior Member
Thanks: Gave 695, Got 87 | Re: Brodit iPhone holder - will the standard one take iPhone in a Incipio Feather cas Quote:
I got mine from DSL Developments as they take Paypal and i had the money in my Paypal account. However the cheapest i have found is a seller on Amazon Marketplace called 'The_Mount_Shop' (although the actual Proclip was slightly more expensive). | Thanks for keeping us informed, I especially found it useful as I think we have both gone for the same set up, do you have this mount... BRODIT PROCLIP 915290 PASS THROUGH HOLDER - iPHONE 3GS on eBay (end time 02-Nov-09 15:56:45 GMT) I bought the cable you recommended and it came through the post today. Not tried it out yet though.
Thanks again
__________________ Samsung LE40N73, Logitech Z-5500, SKYHD, Apple 2008 Aluminium Macbook, UK black slim & lite PSP, UK PS3, PS3 id: stoosheeuk, 16gb iPhone 3G S, Canon EOS 450D |
03-11-2009, 5:58 PM
#8 (permalink)
| | Prominent Member
13-11-2009, 8:22 PM
#9 (permalink)
| | Senior Member
Thanks: Gave 513, Got 163 | Re: Brodit iPhone holder - will the standard one take iPhone in a Incipio Feather cas
Thanks from me too Auto for your cable recommendation. This and a Proclip/Brodit mount (the one that clamps the connector) have made my car iPhone experience twice as good! Two things to note:
1. If you get the Brodit that clamps the connector don't be put off by the the 3-in-1 cable not seeming to fit - you just have to force it in and then the 'locking hooks' on the cable are held pressed by the mount - phew! :-)
2. The line level is a little low but, if you're playing a quiet track and the interference is worrying you, you can just unplug the USB cable from the charger for a short while. This holder means that the phone still sends the line out regardless.
All in all I can thoroughly recommend this solution. My wife bought a TomTom mount for nearly twice the price and although it does handsfree better and has the GPS booster it's nowhere near as neat, doesn't put the phone within easy reach and the line level output is noisier.
Good AVFing!
__________________ Yeah, it’s part of a...trilogy really, a musical trilogy I’m doing... in... D minor... |
