24-10-2009, 10:22 PM
#1 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Listening to BBC Radio 4 on the iPhone
Does anyone know how to about listening to BBC Radio 4 on the iPhone, without the need to spend £3 to £5 on an application (I do after all pay a license fee!)
24-10-2009, 10:26 PM
#2 (permalink)
| | Member
Thanks: Gave 10, Got 46 | Re: Listening to BBC Radio 4 on the iPhone
24-10-2009, 10:47 PM
#3 (permalink)
| | Member
Thanks: Gave 18, Got 7 | Re: Listening to BBC Radio 4 on the iPhone Quote:
Originally Posted by pythagoras | Even better, download Wunderradio from the App Store or TuneWiki
Bob
Watching: JVC LT-40DS7,Sky HD,Samsung DV-HD850, Tivo (2 x 250GB)
Listening : Philips Streamium WACS700, Denon AVR-1706, B&W 602S3s and M1 surrounds
24-10-2009, 11:05 PM
#4 (permalink)
| | Member
Thanks: Gave 10, Got 46 | Re: Listening to BBC Radio 4 on the iPhone Quote:
Originally Posted by tetstb Even better, download Wunderradio from the App Store or TuneWiki | Wunderradio costs £3.99,the op wants free. I cant find radio 4 in tunewiki is there a search function?
Regards
John.
24-10-2009, 11:12 PM
#5 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: Listening to BBC Radio 4 on the iPhone
Thanks for the links guys, I also found this website: BBC Radio iPhone Streams which gives you all the links to the BBC Radio streams as well as a handy tutorial to using them with Fstream.
Pythagoras is that where you got those links from?
24-10-2009, 11:38 PM
#6 (permalink)
| | Member
Originally Posted by JamesCoombs Thanks for the links guys, I also found this website: BBC Radio iPhone Streams which gives you all the links to the BBC Radio streams as well as a handy tutorial to using them with Fstream.
Pythagoras is that where you got those links from? | Yes and they work great too
Regards
John.
25-10-2009, 2:58 PM
#7 (permalink)
| | Member
Originally Posted by pythagoras Wunderradio costs £3.99,the op wants free. I cant find radio 4 in tunewiki is there a search function?
Regards
John. | I didnt realise they had started charging for Wunder Radio, I got it for free.
Bob
25-10-2009, 3:11 PM
#8 (permalink)
| | Prominent Member
Thanks: Gave 252, Got 446 | Re: Listening to BBC Radio 4 on the iPhone
Internet radio box is good too.
Cheers, Auto. Lounge: Panasonic P37X10, Topfield 5810 PVR, Philips BDP3000, Squeezebox 3, Harmony One, Cambridge Audio 640A, Mission 701's Kitchen: Squeezebox Touch, Trends TA-10.1, Kef Cresta 1's. Bedroom: Squeezebox Boom Bathroom: Squeezebox Radio Car: iPod Classic 80Gb Portable: iPhone 3GS 32Gb |
25-10-2009, 3:20 PM
#9 (permalink)
| | Member
Thanks: Gave 12, Got 138 | Re: Listening to BBC Radio 4 on the iPhone
I think it's worth paying a few quid for one of the paid apps which, IMO, hold a signal better.
I prefer ooTunes.
25-10-2009, 7:40 PM
#10 (permalink)
| | Member
Thanks: Gave 7, Got 5 | Re: Listening to BBC Radio 4 on the iPhone Quote:
Originally Posted by UEF I think it's worth paying a few quid for one of the paid apps which, IMO, hold a signal better.
I prefer ooTunes. | Yes, free is great but some of the Apps are really good and, IMHO, worth forking out for (Wunder Radio at £3.99 does it for me)
__________________ Toshiba 40XF355DB | Humax Foxsat PVR | Sony BDS350 | Sony RDRHXD870 | Sony HTSS1300 | Neuros 2 MP4 | Sony MDJB920 | Sony TAFB820R | Sony CDXB920E | Mission 700 | PSP1/2/3000 | Kameleon URC-8308 |iPhone 3GS |
25-10-2009, 8:37 PM
#11 (permalink)
| | New Member
Thanks: Gave 0, Got 1 | Re: Listening to BBC Radio 4 on the iPhone
I listen to radio 4 every morning on my phonevia the free app called tunin.fm aka Icar radio lite. Takes a couple of minutes to buffer when it's opened but works perfectly after that even with no 3g signal. Highly recommended and seems to have hundreds of stations to choose from.
27-10-2009, 6:30 PM
#12 (permalink)
| | New Member
Thanks: Gave 3, Got 1 | Re: Listening to BBC Radio 4 on the iPhone
I notice when using Fstream over GPRS or 3G that the stations keeps cutting out and rebuffering due to bandwidth issues(its fine over Wifi). I presume this would be the same for any app?
I dont want to pay for one of these other apps then find out I am no better off.
27-10-2009, 6:38 PM
#13 (permalink)
| | Prominent Member
Thanks: Gave 252, Got 446 | Re: Listening to BBC Radio 4 on the iPhone Quote:
I prefer ooTunes. | what do you mean 'hold a signal better'?
27-10-2009, 7:08 PM
#14 (permalink)
| | Member
Thanks: Gave 7, Got 13 | Re: Listening to BBC Radio 4 on the iPhone
another vote for radio box from me. its pretty solid on 3g and edge looks nice sound nice and is only 59p
27-10-2009, 8:55 PM
#15 (permalink)
| | Prominent Member
Originally Posted by isaachuntuk I notice when using Fstream over GPRS or 3G that the stations keeps cutting out and rebuffering due to bandwidth issues(its fine over Wifi). I presume this would be the same for any app?
Cheers | You should not have any problems with 3g, but with GPRS you will have problems. Over GPRS you can only stream very low bitrate audio (64kbps if not less) which will sound pretty poor especially with music. It does not mater which app you use, you will always bit at the mercy of the stations bitrate and your network bandwidth. Basically you need wifi or a solid 3g connection. No app really works any better than any other in this respect, or improve sound quality, better apps will just give you better UI, features and stream type support etc.
