Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs > iPhone Discussions
Latest AVForums Movie Reviews
Clash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray Review
Toy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD Review
Thread Thread Starter Forum Replies Last Post
Cannot connect when WEP encryption is turned on. Spudzz Windows 3 15-08-2009 2:01 PM
Archos 605 Wep key not accepted Tiff Portable DVD and Media Players and Recorders 1 17-02-2009 1:49 PM
Using WEP and connecting to Xbox Live bayushi slick Xbox Live 4 27-01-2009 8:45 PM
Wep Key & DVR Problem Badgeman111 Portable DVD and Media Players and Recorders 2 11-01-2009 9:27 PM
Old 17-10-2009, 5:20 PM   #1 (permalink)
Thanks: Gave 10, Got 6
wep key???
Hi i have been using my 3gs fine on my home network with a wpa key. Went to my dads to show off my phone but it wont connect to his wireless router i put the password in with capslock ect but wont connect. If i disable security to router it connects fine. Even if i use wpa key it connects ok. Does the iphone 3gs have problem with WEP keys?? If it does thats very poor of apple i have the latest 3gs software aswell. any help please
paulm34 is offline   Reply With Quote
Old 17-10-2009, 7:05 PM   #2 (permalink)
rafe17's Avatar
Thanks: Gave 28, Got 219
Re: wep key???
WEP is seriously not secure and can be easily broken by hackers so I would advise that you consider changing your method of encryption.
Doesn't answer your question I know but I thought I would let you know.
Apple Alu Macbook Pro 15" 2.66GHz, Macbook 13" 2.4GHz, iPhone 3GS 32GB, Time Capsule 1TB, iPod Nano 4G 8GB / Samsung LE40M87 / Denon AVR-1910 / KEF KHT 2005 5.1 Surround / Sony BDP-S363 Blu-Ray Player / Sky HD / Xbox 360 / Nintendo Wii / Panasonic Lumix LX3
rafe17 is offline   Reply With Quote
Old 18-10-2009, 9:10 AM   #3 (permalink)
Re: wep key???
I have told my dad about changing it to wpa2. But due to him having a old USB wireless adaptor which only supports wep on his second computer. But that has still not answers the question does the iPhone support wep? Is anybody else use wep and can connect? I myself have a 64digit wpa2 key which is a pain to type in
Old 18-10-2009, 9:13 AM   #4 (permalink)
Thanks: Gave 0, Got 2
Re: wep key???
yes i am connected to wep wifi now on my iphone try a reboot of the phone
thenorth is offline   Reply With Quote
Old 18-10-2009, 12:09 PM   #5 (permalink)
Re: wep key???
Hi thanks for reply how do you do a reboot?
Old 18-10-2009, 12:21 PM   #6 (permalink)
Re: wep key???
Just turn the phone off then on also try turning wifi off and on again
Old 18-10-2009, 12:31 PM   #7 (permalink)
Thanks: Gave 12, Got 9
Re: wep key???
Mines currently connected via WEP, as having problems with my iPhone pulling a decent connection when on WPA2
Frostygills is offline   Reply With Quote
Old 18-10-2009, 12:47 PM   #8 (permalink)
Re: wep key???
Oh right thought it might be a hard reset option I did try the wifi off and back on but still the same I back home now so shall switch it off and on next time I'm there but I switch my phone off every night anyway
Old 18-10-2009, 2:12 PM   #9 (permalink)
Thanks: Gave 59, Got 313
Re: wep key???
have you tried entering the password exactly rather than all caps? also, the first time you connect i think you may have to enter the password in twice.
Apple iPhone 3G | Apple Macbook | Canon Ixus 65 | Canon EOS 450D | Panasonic TX-32LXD500 | Sony HDR-SR11 | Sony PSP | Sony PS3
Flickr
achoudry is offline   Reply With Quote
key, wep
Copyright © 2000-2010 M2N E. & O. E.
