Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs > iPhone Discussions
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Old 27-07-2009, 12:59 PM   #1 (permalink)
Post mp3,players,suitable,audiobooks
I would like to buy my wife of 75 an MP3 for her to listen to audiobooks. Considering that a book can be quite long to be read in one go, I am having trouble with finding one that can be restarted where it was left off when switched back on. It would be greatly appreciated if anyone can suggest one that can do this without too many difficulties?
linos is offline   Reply With Quote
Old 27-07-2009, 3:54 PM   #2 (permalink)
sneeks's Avatar
Thanks: Gave 112, Got 188
Re: mp3,players,suitable,audiobooks
The iPod Touch is capable of doing this with any audiobook synced to the device via iTunes, I'm in the process of listening to the latest Karin Slaughter book using this method. I'd imagine the other iPod's in the range, excluding the Shuffle, can do the same.
Panasonic TH42PX70 Plasma - Denon 1909 - Sony PS3 - V+ PVR - 20" C2D iMac - 13" MacBook Pro - Acer Revo 3610
PSN ID: SneekyB
sneeks is offline   Reply With Quote
Old 27-07-2009, 4:00 PM   #3 (permalink)
Smile Re: mp3,players,suitable,audiobooks
Thanks Sneeks, will have a look.
Old 27-07-2009, 4:08 PM   #4 (permalink)
sneeks's Avatar
These screenshots demonstrate how easily I can return to where I was listening at a later time
PSN ID: SneekyB
Old 27-07-2009, 5:28 PM   #5 (permalink)
Post Re: mp3,players,suitable,audiobooks
Thanks for the visual display Sneek. What worries me with regards to Ipod, is that someone commenting on Amazon's shop stated that with itunes one was stuck with them even if he had his own stuff to transfer. I was also hoping to pay a bit less than £152 (cheapest i could find) and the Classic is even dearer, because of it's capacity of 120GB, which we'll never need. You don't happen to know if the Sansa View 8GB can restart where it was stopped do you? That would be an ideal situation because of it's spec, and know where to get it for £60. Thanks again.
Old 27-07-2009, 6:36 PM   #6 (permalink)
sneeks's Avatar
Yes the Sansa View does support resume mode so long as the books have been downloaded from Audible.com which is the book store the Sansa has inbuilt support for.
PSN ID: SneekyB
Old 27-07-2009, 7:10 PM   #7 (permalink)
Thanks Sneek. I have only got into the modern tech stuff since I retired in 1999, so I'm still learning. I live in hampshire, but when i left Submarines in faslane in 1985, I worked in Glasgow for the Co. Ciao and thanks again.
Old 27-07-2009, 7:47 PM   #8 (permalink)
sneeks's Avatar
A old boss of mine used to work in Submarines at Faslane too, I think he left around a similar time to you.
PSN ID: SneekyB
Old 28-07-2009, 6:39 PM   #9 (permalink)
Hi Sneek, After all I went and bought the Zen MX 8GB this afternoon. I hope I will be able to get my wife going on it when I've charged and sorted it out. Some author on the web called Stuart Andrews gives it a fair report. I"ll let you know how I get on. Btw I was Queens Harbour Masters Assistant in Faslane and I come from Malta originally, so the guy you know will most probably know. Take care and thanks.
audiobooks, mp3, players, suitable
Copyright © 2000-2010 M2N E. & O. E.
