Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs > iPhone Discussions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Mobile PhonesCompare Apple iPhone 3G deals
Old 05-07-2009, 7:47 PM   #1 (permalink)
help
I've got o2 business account and tomorrow i go from my N95 to the iphone 3g. These may seem basic questions but can someone help.
Do i use my old sim card or does the iphone come with a sim with my old number?
If i use my old sim card how do i get it into the phone, I can't beleive the paper clip is the official way!
Thanks in advance of some guidance.
Chris
silvermilnec is offline   Reply With Quote
Old 05-07-2009, 8:37 PM   #2 (permalink)
filmfreak71's Avatar
Thanks: Gave 95, Got 235
Re: help
I take it you are buying a new phone, or are you getting a second hand one? If it is a new one then you will get a new sim card with it, as I was told that the iPhone needed a new compatible sim card to work (however almost every phone I've bought over the last several years has come with a new sim card and told the same thing!)
New iPhone will have the official sim card removal tool in the box, which basically is a pre-bent paper clip.
Enjoy... I'm lovin' mine!
Setup: Toshiba 32WLT58, Yamaha DSP-AX630SE, KEF KHT-2005.2, Panasonic DMR-E55 DVD Recorder, Xbox-360
Favourite DVDs: Sin City Sp Ed, Kill Bill V1 & 2, Fight Club, Usual Suspects, LOTR Trilogy Sp Ed
Currently Playing: Tomb Raider Underworld, Banjo, Left4Dead, and Peggle My flickr photo library
filmfreak71 is offline   Reply With Quote
Old 05-07-2009, 10:20 PM   #3 (permalink)
Re: help
Cheers, it is a new phone and i've found the bent paper clip! i'll take a look to see if the sims inside.
If i do use my old sim do you know if you can transfer contacts from the sim?
Thanks Chris
Old 06-07-2009, 12:29 AM   #4 (permalink)
as20's Avatar
Thanks: Gave 6, Got 121
Re: help
Thanks Chris
From your sim to the phone or sim to sim?
as20 is offline   Reply With Quote
Old 06-07-2009, 9:02 AM   #5 (permalink)
Re: help
I've done the contacts
I've got the unlimited data package but when i press to go onto the internet i get the message "you are not subscribed to a cellular data network"
Any clues?
Old 06-07-2009, 10:19 AM   #6 (permalink)
Re: help
You might have to check that the unlimited data package cover iPhone, because when I joined I got an specific iPhone bolt on that was actually included in the price.
Old 09-07-2009, 2:06 PM   #7 (permalink)
Re: help
o2 had not turned me on. All on now, thanks for the help.
