Air Mouse
Old 26-04-2009, 8:52 PM   #1
pdiddy's Avatar
4,068, Level: 15
Points: 4,068, Level: 15 Points: 4,068, Level: 15 Points: 4,068, Level: 15
Thanks: Gave 33, Got 39
Air Mouse
Just discovered air mouse, what a cracking little app. it basically allows you to use your iphone as a wireless mouse pad.
Superb if you link your laptop up to your big screen tv. You also get a key board with the app so you can use all functions on your computer.
Try it, it's ace
Old 26-04-2009, 9:49 PM   #2
6,217, Level: 18
Points: 6,217, Level: 18 Points: 6,217, Level: 18 Points: 6,217, Level: 18
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 175, Got 360
Re: Air Mouse
I use this app all the time too. It's brilliant! Does everything you'd expect. Also, something I didn't realise for quite a long time, if you give it a vertical shake then it hides/displays the keyboard. It's good to hide it and have the iPhone as a full screen touch pad
Old 01-05-2009, 8:04 PM   #3
daz4590's Avatar
3,818, Level: 14
Points: 3,818, Level: 14 Points: 3,818, Level: 14 Points: 3,818, Level: 14
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 6, Got 18
Re: Air Mouse
Yeh I love this application. I don't use it as much as I'd like but it is definitely useful
