how many iphones can be on 1 itunes account please help
Old 22-10-2009, 5:06 PM   #1
YO YO's Avatar
2,301, Level: 11
Points: 2,301, Level: 11 Points: 2,301, Level: 11 Points: 2,301, Level: 11
Thanks: Gave 92, Got 5
hi how may iphones can be on one itunes account as i am on my 4th iphone at the min and just thinking about getting tom tom and if so how long it will last me
thanks please help
Old 23-10-2009, 8:03 AM   #2
filmfreak71's Avatar
14,279, Level: 28
Points: 14,279, Level: 28 Points: 14,279, Level: 28 Points: 14,279, Level: 28
Activity: 4.5%
Activity: 4.5% Activity: 4.5% Activity: 4.5%
Thanks: Gave 148, Got 356
Re: how many iphones can be on 1 itunes account please help
As far as I'm aware there is no limit to the number of iPhones you tie to your account, certainly in your case there you are going from 1 to another.
Not sure what you mean about how long Tom Tom will last you???
YO YO (24-10-2009)
Old 24-10-2009, 2:37 PM   #3
YO YO's Avatar
2,301, Level: 11
was thinking off butting tom tom on my iphone and my birds cause they are both on the same itunes accound so it should work ok??
Old 24-10-2009, 3:06 PM   #4
sammy4499771's Avatar
8,842, Level: 22
Points: 8,842, Level: 22 Points: 8,842, Level: 22 Points: 8,842, Level: 22
Thanks: Gave 34, Got 100
Should be fine.
