Tioti+ remote record prob
Old 18-10-2009, 2:37 PM   #1
4,416, Level: 15
Points: 4,416, Level: 15 Points: 4,416, Level: 15 Points: 4,416, Level: 15
Thanks: Gave 4, Got 3
I have sky+ and tioti+ on my iPhone. I much prefer the tioti+ interface but the record button never works. I get the following error message:
Received error response from Sky. Please make sure that you can remote record from the Sky web site before trying again
With the Sky+ app, remote record works fine
Any ideas why tioti+ remote record doesn't work?
Old 19-10-2009, 6:56 AM   #2
2,534, Level: 11
Points: 2,534, Level: 11 Points: 2,534, Level: 11 Points: 2,534, Level: 11
Thanks: Gave 22, Got 11
Re: Tioti+ remote record prob
Works fine for me, as you mentioned it works fine with the sky app I would advise to delete and reinstall tioti app
Old 20-10-2009, 10:18 AM   #3
4,416, Level: 15
Hi evo97
Thanks - tried that but it still doesn't work
I wonder if the fact that the sky+ app works and tioti+ app doesn't is related - ie only one of them can work to remote record for any given machine/ account at anyone time?
Old 20-10-2009, 1:04 PM   #4
1,952, Level: 10
Points: 1,952, Level: 10 Points: 1,952, Level: 10 Points: 1,952, Level: 10
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 3, Got 3
I had a problem when I first got the tioti app in that the record command would only work over wifi and not 3G, I emailed the makers and they were really helpful. I sent off some info for them and a few days later it worked?!?
Might be coincidence but I was happy.
Joe
Old 25-10-2009, 5:29 PM   #5
Scapegoat's Avatar
12,052, Level: 26
Points: 12,052, Level: 26 Points: 12,052, Level: 26 Points: 12,052, Level: 26
Thanks: Gave 383, Got 129
It asks for Sky username and password - is that the details I use to log onto the Sky website to do remote record from the web?
If so mine doesn't work either over Wifi (its a touch not a phone) and get the same error message.
