I need a longer charge cable !
Old 05-03-2012, 7:22 PM   #1
DodgeTheViper's Avatar
Location: Searching for . . The best that I can get :-)
Thanks: Gave 347, Got 696
Can anyone suggest a decent usb charge cable that will work with iPhone 4s, iPad2, iPod Touch and a Classic. Needs to be around 2 mtrs or so.
Old 05-03-2012, 8:15 PM   #2
Senior Moderator
Steven's Avatar
Thanks: Gave 2,363, Got 5,151
http://www.amazon.co.uk/7dayshop-Cab...dp/B005MQI8UG/
KanaaN USB Data Sync and Charging Cable for Apple: Amazon.co.uk: Electronics
High Grade - Extra Long USB Sync & Charge Cable for: Amazon.co.uk: Electronics
No personal experience myself but why not take one for the team?
DodgeTheViper (05-03-2012)
Old 05-03-2012, 8:27 PM   #3
I seen those, but the reviews are a bit hit and miss. Looks like I may just have to pick one.
Old 05-03-2012, 8:36 PM   #4
Senior Moderator
Steven's Avatar
Know what you mean. Recently purchased a Touch 4G off the forum and then noticed the cable had become exposed from the usb end. So have purchased a cheapo option (so cheap it comes in a pack of two) and then splurged out near £8 on the fancy Belkin iPod cable off Amazon It'll be a contrast if nothing else!
Old 05-03-2012, 8:42 PM   #5
Seen the Belkin one as well, it's just not long enough for me unfortunately.
Old 05-03-2012, 8:58 PM   #6
Thanks: Gave 21, Got 626
USB extension along with your current cable!
Old 05-03-2012, 9:01 PM   #7
Thanks: Gave 3, Got 5
I picked up a 3 metre iPhone/pad cable from Currys for £15.00. Much thicker cable than the original iPhone cable as well, so not going to break easily.
Old 05-03-2012, 9:03 PM   #8
I looked at those, but just didn't like the idea. Will probably get more than one cable as well.
Old 05-03-2012, 9:04 PM   #9
Expensive, but I might take a look at that one, cheers
Old 05-03-2012, 9:05 PM   #10
I wouldn't use one but in case you were after a really cheap option that's all. You can get them for pence. I think a quality cable is best tbh but may have been helpful to you.
Old 05-03-2012, 9:07 PM   #11
No probs, good luck with the search
Old 05-03-2012, 9:10 PM   #12
Checking that cable out now.
Old 06-03-2012, 9:30 AM   #13
For info, i've ordered the 2m cable from 7dayshop
Old 09-03-2012, 9:39 PM   #14
Senior Moderator
Steven's Avatar
Just for info, whilst the Belkin is only 1.2m, it is superbly made as one expects from such an established accessory manufacturer. Plug and connection ends are thick and solid. Counting against it is the fact it costs nearly £8
The cheapo ones also arrived, blink and they could be official Apple stock
Old 09-03-2012, 9:43 PM   #15
Mine isn't here yet. If the Belkin was longer I may have gone for it. Which cheaper one did you go for ?
Old 09-03-2012, 9:48 PM   #16
pixelpixel's Avatar
Thanks: Gave 2,031, Got 1,554
I have this: 5m USB Extension Cable it works a treat.
Old 09-03-2012, 9:56 PM   #17
Personally, I wasn't looking for an extension cable so I discounted them.
Old 10-03-2012, 9:04 PM   #18
Senior Moderator
Steven's Avatar
2 X Apple iPad 2 & iPad & iphone 4S iPhone 4 3GS 3G USB: Amazon.co.uk: Electronics
Ordered from Tech Galaxy reseller
Old 10-03-2012, 11:26 PM   #19
pixelpixel's Avatar
Old 10-03-2012, 11:31 PM   #20
Originally Posted by pixelpixel View Post
And that means what ?
Old 11-03-2012, 12:06 PM   #21
Fe+ Fe+ is offline
Fe+'s Avatar
Thanks: Gave 17, Got 4
i have this and the car charger usb mini plug - works great
Old 11-03-2012, 12:45 PM   #22
Great stuff. Did u get the USB socket from 7dayshop as well ?
Old 13-03-2012, 1:02 AM   #23
Thanks: Gave 2, Got 1
[URL="http://www.7dayshop.com/catalog/product_info.php?cPath=777_12&products_id=111263"]
Not sure if I inserted the link correctly..its the 2m usb cable for the iphone 4 from 7dayshop, I wanted a longer charge cable so bought this about 2 weeks ago. Took the original short lead out of the 4s charger and inserted the longer cable, I have been using this with no problems.
