iPhone Dock for around £70
Old 17-09-2009, 8:05 PM   #1
Enzo-Amata's Avatar
1,776, Level: 9
Points: 1,776, Level: 9 Points: 1,776, Level: 9 Points: 1,776, Level: 9
Thanks: Gave 3, Got 0
I'm looking to get some feedback from you guys. I only use my iPhone for podcasts and I'm looking for a docking system with speakers which has its own mains power...
Anyone have any good suggestions they can recommend?
Old 17-09-2009, 8:10 PM   #2
2,963, Level: 12
Points: 2,963, Level: 12 Points: 2,963, Level: 12 Points: 2,963, Level: 12
Thanks: Gave 96, Got 110
Re: iPhone Dock for around £70
I use a Cambridge audio ID10 - just connects to my existing system via phono - charges the ipod and i can use my harmony remote
cheap as chips too
Old 17-09-2009, 8:45 PM   #3
Enzo-Amata's Avatar
1,776, Level: 9
cheap as chips too
This is just a dock. That's not what I was asking but thanks anyways...
Old 17-09-2009, 9:58 PM   #4
3,540, Level: 13
Points: 3,540, Level: 13 Points: 3,540, Level: 13 Points: 3,540, Level: 13
Activity: 2.8%
Activity: 2.8% Activity: 2.8% Activity: 2.8%
Thanks: Gave 35, Got 29
I have the Logitech Pure-Fi Anywhere 2:
Logitech PURE-FI ANYWHERE 2 IPOD/IPHONE SPEAKER SYSTEM review cheap prices PURE-FI ANYWHERE 2 IPOD/IPHONE SPEAKER SYSTEM Logitech best buy discount online uk shop
Got excellent sound for a smallish dock, plus has a built-in rechargeable battery which I found dead handy for camping trips. Also has a remote control and comes with international travel adaptors if taking abroad on holiday.
Old 17-09-2009, 10:20 PM   #5
boltlock's Avatar
4,947, Level: 16
Points: 4,947, Level: 16 Points: 4,947, Level: 16 Points: 4,947, Level: 16
Activity: 19.3%
Activity: 19.3% Activity: 19.3% Activity: 19.3%
Thanks: Gave 179, Got 231
I have a Sony ICF-C1ipMK2 and it's very nice system with a decent sound and comes with a remote too. The only negative I can think of is that the display can be a little too bright for bedroom use but that can be quite easily sorted. Can be picked up for around £60.
Old 17-09-2009, 10:21 PM   #6
mattg's Avatar
9,078, Level: 22
Points: 9,078, Level: 22 Points: 9,078, Level: 22 Points: 9,078, Level: 22
Activity: 27.0%
Activity: 27.0% Activity: 27.0% Activity: 27.0%
Thanks: Gave 263, Got 296
interesting dock you linked to. What is the battery like in real world?
Old 18-09-2009, 3:13 AM   #7
6,995, Level: 19
Points: 6,995, Level: 19 Points: 6,995, Level: 19 Points: 6,995, Level: 19
Activity: 10.5%
Activity: 10.5% Activity: 10.5% Activity: 10.5%
Thanks: Gave 76, Got 291
Originally Posted by Enzo-Amata View Post
Ive got a bose sound dock. If you look hard enough you could find one of the older ones for around £70... its not a patch on the hifi BUT, compared to other docks its bloody brilliant.
Old 18-09-2009, 9:50 AM   #8
3,540, Level: 13
Activity: 2.8%
Having used it in reasonably small chunks over a two week camping trip it's hard to say exactly. We were well into the second week before needing to recharge it though. The quoted 10 hours is possibly a little optimistic, but I'm certain I get at least 8 hours plus between charges.
Old 20-09-2009, 5:16 PM   #9
1,659, Level: 9
Points: 1,659, Level: 9 Points: 1,659, Level: 9 Points: 1,659, Level: 9
Thanks: Gave 4, Got 0
I second that...
I'm looking for a Speaker Dock, my Dad is trying to give me his Tangent Speakers but I need a HiFi for that and its just not suitable for a bedroom situation.
I'm returning my Altec Lansing M402 which anyone should avoid like the plague because they are shockingly bad.
I need something shielded, stylish, good sound and a fairly loose budget of £70.
I must say I am super tempted by the Vers 2x which just looks amazing and the sound should be pretty good too but I think it might just be a little to pricey.
Anyone recommend any alternatives?
Old 20-09-2009, 6:19 PM   #10
Butters's Avatar
6,896, Level: 19
Points: 6,896, Level: 19 Points: 6,896, Level: 19 Points: 6,896, Level: 19
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 134, Got 89
Mmm - possibly more than you were looking to spend but i use a JBL200 dock. For me it ticked all the right boxes in terms of power output, looks and above all sound quality.
http://www.avforums.com/forums/iphon...w-opinion.html
Old 20-09-2009, 10:47 PM   #11
Enzo-Amata's Avatar
1,776, Level: 9
Just to add to the mix something I've just found out by looking for a dock is that I infact have an iPhone and need to make sure that its compatable or if I do infact plug my iPhone into a dock that isn't, it puts my phone in aeroplane more and I cant recieve calls.
Old 21-09-2009, 7:10 AM   #12
1,659, Level: 9
What your looking for is a "sheilded" speaker, common on higher end units it means you don't get that annoying interference.
I think I am going to save up and get the stunning Vers 2x for about £150 over here in the UK.
Old 21-09-2009, 8:03 PM   #13
Butters's Avatar
6,896, Level: 19
Activity: 0.7%
I can tell you from experience that even the docks that are shielded and iPhone compatible still bring up the - this is not compatible do you want to go into airplane mode dialogue box. You just get used to ignoring it.
The JBL 200 does that, so do the Bose docks!!
They both work fine without the annoying interference noise and can take incoming calls.
Old 21-09-2009, 9:28 PM   #14
RobM's Avatar
36,082, Level: 46
Points: 36,082, Level: 46 Points: 36,082, Level: 46 Points: 36,082, Level: 46
Activity: 35.8%
Activity: 35.8% Activity: 35.8% Activity: 35.8%
Thanks: Gave 854, Got 1,712
You're talking about two different things....
The shielding protects the speaker from phone interference. This is the important bit for use with the iPhone as the noise you get is bloody annoying.
The message you get means the manufacturer hasn't paid out to Apple to make their product an authorised / licensed product. This is mildly annoying, having to dismiss the message, but big wow.
Old 22-09-2009, 10:12 AM   #15
Alison22uk's Avatar
3,118, Level: 13
Points: 3,118, Level: 13 Points: 3,118, Level: 13 Points: 3,118, Level: 13
Thanks: Gave 42, Got 35
I run the Sony ICF-C1ipMK2 and it never comes up with this message and works flawlessly too in terms of receiving calls and text messages.
Old 22-09-2009, 8:37 PM   #16
3,540, Level: 13
Activity: 2.8%
The Logitech I originally linked is also fully iPhone compatible and doesn't display the accessory message or suffer with any interference probs.
Old 22-09-2009, 10:08 PM   #17
Butters's Avatar
6,896, Level: 19
Activity: 0.7%
Yes i know - just didn't explain it very well
Powered by
 Latest popular product prices
Apple iPhone 4 Universal Dock Ad...
1 price
 £11.50 Click to show/hide the offers
Apple iPhone Micro USB Adapter
1 price
 £12.50 Click to show/hide the offers
Belkin Stereo Cable for iPhone/i...
1 price
 £17.95 Click to show/hide the offers
Apple Battery Charger
1 price
 £29.50 Click to show/hide the offers
Apple iPhone 4 Bumper - White
1 price
 £30.50 Click to show/hide the offers
Apple iPhone 4 Bumper - Blue
1 price
Apple iPhone 4 Bumper - Orange
1 price
Apple iPhone 4 Bumper - Green
1 price
 Updated February 13th at 12:30am. Prices include delivery.
