If a car charger works with iphone 3g, will it work with 3gs?
Old 13-07-2009, 5:28 PM   #1
8,585, Level: 22
Points: 8,585, Level: 22 Points: 8,585, Level: 22 Points: 8,585, Level: 22
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 5, Got 26
So if an ebay item states that it charges the iphone 3g, does that mean it will def work withthe 3gs:
Such as this:
USB CABLE+AC WALL+CAR CHARGER FOR APPLE IPOD IPHONE 3G on eBay (end time 11-Aug-09 16:18:50 BST)
Old 13-07-2009, 6:45 PM   #2
2,107, Level: 10
Points: 2,107, Level: 10 Points: 2,107, Level: 10 Points: 2,107, Level: 10
Thanks: Gave 26, Got 12
Re: If a car charger works with iphone 3g, will it work with 3gs?
I may be wrong but im sure all Ipod/touch/Iphone connectors are the same
Old 13-07-2009, 6:48 PM   #3
Conspicuous Member
37,505, Level: 47
Points: 37,505, Level: 47 Points: 37,505, Level: 47 Points: 37,505, Level: 47
Activity: 25.0%
Activity: 25.0% Activity: 25.0% Activity: 25.0%
Thanks: Gave 4,677, Got 1,527
Exclamation Re: If a car charger works with iphone 3g, will it work with 3gs?
Actually, not all iPhone, iPod, or iTouch connectors are the same. They may all look identical to the naked eye, and even fit correctly, but you may find - as I did the other day - that even if they do fit and look ok, the iPhone will come-up with a message saying that "This device is not correct for your iPhone", and wil simply not let it charge the battery.
Be sure to get a dedicated 3G, or 3GS charger, if that's what you are looking for, depending on which iPhone you own.
Pooch
Old 13-07-2009, 8:49 PM   #4
RobM's Avatar
36,093, Level: 46
Points: 36,093, Level: 46 Points: 36,093, Level: 46 Points: 36,093, Level: 46
Activity: 32.1%
Activity: 32.1% Activity: 32.1% Activity: 32.1%
Thanks: Gave 854, Got 1,712
Pooch is totally spot on in saying the iPod/iSomethingElse connections changed a while ago which can prevent a device charging if an incorrect cable or charger is used. The pin that charges was the key change here.
But the iPhone 3G and 3GS were both post this change, so chargers and cables that work for one, work with the other
PoochJD (14-07-2009)
Old 13-07-2009, 10:52 PM   #5
mr.manchester's Avatar
2,702, Level: 12
Points: 2,702, Level: 12 Points: 2,702, Level: 12 Points: 2,702, Level: 12
Thanks: Gave 54, Got 71
I got a USB adapter for my cigarette lighter, used the standard apple charge cable with it, the 3G charged fine but my 3GS wouldn't charge atall, came up saying "not compatable" on the screen.
Old 14-07-2009, 6:13 AM   #6
2,535, Level: 11
Points: 2,535, Level: 11 Points: 2,535, Level: 11 Points: 2,535, Level: 11
Thanks: Gave 11, Got 45
Such as this:
I do hope you're not thinking of buying that Why spend £200 to £500 on a phone and then risk trashing it by buying a cheap charger?
Old 14-07-2009, 6:29 AM   #7
4,694, Level: 16
Points: 4,694, Level: 16 Points: 4,694, Level: 16 Points: 4,694, Level: 16
Thanks: Gave 1, Got 11
I have a portable power pack that worked fine with the 3g. It will work on the 3gs if you turn the screen off then connect it and it starts to recharge however if the 3gs battery is below 50% charge then doing the above results in it recognising that the portable battery is connected but it will not charge. So i'd say be very wary about buying 3g stuff to use with 3gs.
Old 14-07-2009, 6:58 AM   #8
RobM's Avatar
36,093, Level: 46
Activity: 32.1%
Sounds more like a dodgy adapter to me. Was it an Apple one or a random eBay special?
Old 14-07-2009, 11:54 AM   #9
lentini's Avatar
5,479, Level: 17
Points: 5,479, Level: 17 Points: 5,479, Level: 17 Points: 5,479, Level: 17
Thanks: Gave 11, Got 427
my cheap £1.99 car charger I bought for my 3G works fine on my 3GS
Old 15-07-2009, 1:25 AM   #10
2,702, Level: 12
It was a nasty cheap random mate, lesson learnt!
Old 15-07-2009, 5:49 AM   #11
UEF UEF is offline
7,132, Level: 20
Points: 7,132, Level: 20 Points: 7,132, Level: 20 Points: 7,132, Level: 20
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 26, Got 228
£1 USB adaptor and £1 iPhone cable works fine here
Old 19-07-2009, 6:46 PM   #12
Desmo's Avatar
13,713, Level: 28
Points: 13,713, Level: 28 Points: 13,713, Level: 28 Points: 13,713, Level: 28
Activity: 38.2%
Activity: 38.2% Activity: 38.2% Activity: 38.2%
Thanks: Gave 366, Got 817
I tried my old USB cig socket on my £GS the other day and it didn't work
Thought I'd just be able to pop the standard charging cable in and away I go but no joy. The USB cig charger works fine on my old HTC and on our TomTom unit but no joy with the iPhone.
Will have to get another one ordered up and hope for the best I guess.
Old 19-07-2009, 8:37 PM   #13
Thanks: Gave 10, Got 48
Got one of these for my iphone 3G. Works great, charges the battery quicker than the phone can use when using gps (sygic navigator). Always have a fully charged phone after a long journey
Powered by
 Latest popular product prices
Apple iPhone 4 Universal Dock Ad...
1 price
 £11.50 Click to show/hide the offers
Apple iPhone Micro USB Adapter
1 price
 £12.50 Click to show/hide the offers
Belkin Stereo Cable for iPhone/i...
1 price
 £17.95 Click to show/hide the offers
Apple Battery Charger
1 price
 £29.50 Click to show/hide the offers
Apple iPhone 4 Bumper - White
1 price
 £30.50 Click to show/hide the offers
Apple iPhone 4 Bumper - Blue
1 price
Apple iPhone 4 Bumper - Orange
1 price
Apple iPhone 4 Bumper - Green
1 price
 Updated February 13th at 8:30pm. Prices include delivery.
