QED Sqart, are cable or interface the way to go ?
Old 12-01-2008, 1:30 AM   #1
4,113, Level: 15
Points: 4,113, Level: 15 Points: 4,113, Level: 15 Points: 4,113, Level: 15
Thanks: Gave 26, Got 15
I like the look of these QED Sqart cables and the write ups, can you tell me which is the best way to go in either buying the interface version or the cable version ?
Its just for connecting my Sky+ and my dvd player to my television.
http://www.qed.co.uk/c186-158/QEDCab...htm?mennum=158
Old 12-01-2008, 1:09 PM   #2
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,177
Re: QED Sqart, are cable or interface the way to go ?
I don't know what the "interface" version is but QED make good quality cables. The cheaper one will do. Thor is also a good buy at £18. If you check out some of the threads above, you will see some more recommendations on a budget.
Old 12-01-2008, 1:51 PM   #3
4,113, Level: 15
Thanks.
This is more of what i meant, this one is a cable type
http://www.qed.co.uk/i138c208-186-15...rence_AV21.htm
and this one has an interface type flat cable
http://www.qed.co.uk/i134c207-186-15..._SQart_P21.htm
I was just wondering if one has an advantage of the other in the way they are constructed ?
Old 12-01-2008, 2:06 PM   #4
davepuma's Avatar
32,020, Level: 43
Activity: 29.7%
No difference IMHO. It's just a case of which cable fits your needs, if you don't need a flat cable, just get the ordinary one.
