Help needed - cant use banana plugs - alternatives?
Old 11-01-2008, 11:36 PM   #1
2,726, Level: 12
Points: 2,726, Level: 12 Points: 2,726, Level: 12 Points: 2,726, Level: 12
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 40, Got 13
I cant use banana plugs on my speaker ends now Ive upgraded my speaker cable (too thick!!!).
The sony speakers that came with my old surround sound system (HT-SL50 I think) have those annoying inbuilt connectors (under the base!) that I have to slot the cable directly into (pressing a button whilst doing so). The whole is fairly thin.
Is there a connector I can get that will go into these holes? They seem standard (same on the back of my hifi - have to use your finger to push down the bbutton and slot in the cable at the same time - not sure the official term!).
Thanks from a dunce newbie!
Old 12-01-2008, 1:32 PM   #2
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,177
Re: Help needed - cant use banana plugs - alternatives?
If 2mm banana plugs are still too big, I would just stick with bare wire.
