IEC Connectors
Old 11-01-2008, 10:29 AM   #1
3,939, Level: 14
Points: 3,939, Level: 14 Points: 3,939, Level: 14 Points: 3,939, Level: 14
Thanks: Gave 1, Got 10
IEC Connectors
I've managed to get some decent length of screened shield cable.
Does anyone know where i can buy som decent quality plugs and IEC connectors, preferably with the heatshrinks at the ends?
Old 11-01-2008, 10:56 AM   #2
Conspicuous Member
21,528, Level: 35
Points: 21,528, Level: 35 Points: 21,528, Level: 35 Points: 21,528, Level: 35
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 4, Got 1,393
Re: IEC Connectors
No good? http://www.maplin.co.uk/Search.aspx?...source=15&SD=Y
http://markgrantcables.co.uk/shop/in...index&cPath=16
Old 11-01-2008, 11:50 PM   #3
4,679, Level: 16
Points: 4,679, Level: 16 Points: 4,679, Level: 16 Points: 4,679, Level: 16
Thanks: Gave 59, Got 142
Re: IEC Connectors
£4 for a standard IEC connector? Ouch!
http://www.studiospares.com/pd_57778...BLE%20PLUG.htm
Old 12-01-2008, 12:16 AM   #4
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: IEC Connectors
hmm thats not the IEC end need for a screen see here http://www.russandrews.com/product.a...RUEQIFGWQITXWQ
Plugs http://www.russandrews.com/product.a...RUEQIFGWQITXWQ
