5 metre long, right angled IEC mains lead...where?
Old 10-01-2008, 4:34 PM   #1
tomson's Avatar
7,527, Level: 20
Points: 7,527, Level: 20 Points: 7,527, Level: 20 Points: 7,527, Level: 20
Thanks: Gave 88, Got 189
Does anyone know where I can buy one of these - maplin do a 2m one but so far I haven't been able to find anything longer.
http://www.maplin.co.uk/Module.aspx?...C=SO&U=strat15
Old 10-01-2008, 5:03 PM   #2
13,329, Level: 27
Points: 13,329, Level: 27 Points: 13,329, Level: 27 Points: 13,329, Level: 27
Activity: 44.9%
Activity: 44.9% Activity: 44.9% Activity: 44.9%
Thanks: Gave 1, Got 524
Re: 5 metre long, right angled IEC mains lead...where?
CPC do a 3M one...
You might be better off making one. Just buy the plug and a suitable length of flex.
You can make it exactly the right length then and thread it through small holes if necessary.
Steve
Old 10-01-2008, 7:14 PM   #3
forrestgump's Avatar
8,069, Level: 21
Points: 8,069, Level: 21 Points: 8,069, Level: 21 Points: 8,069, Level: 21
Thanks: Gave 117, Got 54
The right angled IEC will be a slight problem because most of the large outlets like farnell charge lots of postage on orders below £35-£40.00, I will send you one gratis and a mains plug if you send me a couple of quid for the postage and jiffy bag, you will just need to go to b&q or wilkinson and get 5 metres of cable, sorted!
tomson (10-01-2008)
Old 10-01-2008, 7:37 PM   #4
tomson's Avatar
7,527, Level: 20
That's very kind of you. Will drop you a PM.
