Which connections?
Old 28-11-2007, 8:24 PM   #1
3,318, Level: 13
Points: 3,318, Level: 13 Points: 3,318, Level: 13 Points: 3,318, Level: 13
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 3, Got 0
Which connections?
Could you please help me work out the best way to connect the following components:
TV: Panasonic TX-32LXD52
DVD-R: Panasonic DMREZ27
SKY+ Thompson box - not HD.
I'm thinking that the following configuration would be best, but just wanted to check for any other opinions etc.
SKY+ --RGB SCART --> TV
DVD-R--HDMI--> TV
SKY+ --SCART-->DVD-R
Thanks.
Old 29-11-2007, 9:19 AM   #2
Assured Advertiser
Joe Fernand's Avatar
36,535, Level: 46
Points: 36,535, Level: 46 Points: 36,535, Level: 46 Points: 36,535, Level: 46
Activity: 21.3%
Activity: 21.3% Activity: 21.3% Activity: 21.3%
Thanks: Gave 205, Got 1,344
Re: Which connections?
Hello whoever
As the second SCART Out on the SKY+ box is Composite video not RGB your going to limit the quality of your recordings from SKY.
Try SKY+ > SCART (RGB) > DVD-R > HDMI > TV - assuming the DVD-R doesn't mess up the SKY signal on its way through then that is likely your best option.
Joe
Old 29-11-2007, 11:38 AM   #3
2,903, Level: 12
Points: 2,903, Level: 12 Points: 2,903, Level: 12 Points: 2,903, Level: 12
Thanks: Gave 7, Got 0
Hi Joe,
I have a similar set up and was wondering the same as whoever.
From your solution, as the Sky+ box is not HD, would the HDMI cable send the picture from the DVD-R ok?
Old 29-11-2007, 11:48 AM   #4
Assured Advertiser
36,535, Level: 46
Activity: 21.3%
Hello Steven61
In effect the DVD-R becomes your Switching Hub and 'low cost' Analogue to Digital converter in one.
Most DVD-R units with HDMI Outputs will take in Analogue video (Composite, S-Video and RGB SCART) and carry out the required conversion to Digital before outputting on HDMI.
Some units will also offer some form of up-conversion to HD resolution - though that can be a debatable 'upgrade'!
Joe
Steven61 (29-11-2007)
Old 29-11-2007, 9:34 PM   #5
Jamie's Avatar
10,760, Level: 24
Points: 10,760, Level: 24 Points: 10,760, Level: 24 Points: 10,760, Level: 24
Thanks: Gave 93, Got 573
Alternatively the DVDR has RGB scart in and out. so RGB scart sky+ to DVDR then RGB scart DVDR to TV
Might be worth trying as the scaling might be better in your TV than the recorder, you can always remove if the HDMI looks just as good.
Also the HDMI would probably require the DVDR to be trurned on whereas most machines will give you scart pass through when in standby.
Old 29-11-2007, 9:45 PM   #6
3,318, Level: 13
Activity: 1.4%
Thanks for your responses. Its actually my parents setup and neither of us have an HDMI cable to try.
So if I use HDMI from the DVD-R the DVD-R upscales, but if I use RGB Scart the TV will upscale. Correct?
Is there anywhere I can look up opinions on how good the upscaling is for the TV versus the DVD-R. Or even reviews on the upscaling of each of them individually?
Old 29-11-2007, 11:32 PM   #7
Jamie's Avatar
10,760, Level: 24
I'd say the best connection for playing DVD's would be the HDMI so get one anyway, I'd have thought you'd have access to a spare decentish RGB scart (even if you have to borrow from your own setup) and they need at least one scart.
Wire Sky+ -scart- DVDR
and connect both Scart and HDMI from DVD to TV and see which you prefer.
There may not be that much difference but not needing to turn on the DVD to watch sky via scart might be a convenient addition with the 2 scarts way.
If the scart to TV works better either take the opportunity to upgrade yourself to a better scart and leave yours in place or buy a 2nd scart
Old 30-11-2007, 8:42 AM   #8
2,903, Level: 12
So if i was to connect the Sky+ - Scart - DVD-R, DVD-R - HDMI - TV then i'd need the DVD switched on to watch Sky?
Could i use a scart between the Sky box and DVD-R and Sky and TV and then a HDMI from DVD-R to TV?
Would that work?
Old 01-12-2007, 1:48 PM   #9
3,318, Level: 13
Activity: 1.4%
Thanks JimBob, good point.
OK - so they will end up with...
SKY+ --SCART RGB --> DVD-R --HDMI--------->TV
................................DVD-R --(SCART RGB)-->TV
Sounds like a good plan to me...
I'll go and check out the posts on which HDMI cable to buy now :-)
Old 02-12-2007, 9:08 PM   #10
Jamie's Avatar
10,760, Level: 24
of course if the DVD player is on you will be able to watch Sky with HDMI. I presume (most do) that the DVD recorder will give scart passthrough when in standby.
From a parents point of view not having to turn on the DVD recorder to watch TV will be better (basing this on my mum who is absolutley clueless with operating all the kit I have recommended she get )
Steven61 (03-12-2007)
