Will a decent cable help ?
Old 28-11-2007, 8:02 PM   #1
Illustrious Member
signs's Avatar
30,738, Level: 42
Points: 30,738, Level: 42 Points: 30,738, Level: 42 Points: 30,738, Level: 42
Activity: 37.2%
Activity: 37.2% Activity: 37.2% Activity: 37.2%
Thanks: Gave 1,187, Got 2,120
hi all
i'm getting some motion blur when using the EP35 through the Onkyo to the
Sony, will a set (guess i'll need 2 , one from player to amp one from amp to TV)
help?
if so would somebody be so kind a to recommend a decent set of HDMI's
regards
signs
Old 28-11-2007, 8:18 PM   #2
forrestgump's Avatar
8,069, Level: 21
Points: 8,069, Level: 21 Points: 8,069, Level: 21 Points: 8,069, Level: 21
Thanks: Gave 117, Got 54
Re: Will a decent cable help ?
you may not have it all set up correctly mate, check all the settings first, if not mark grant is yer man for hdmi's
www.markgrantcables.co.uk
he is a forum sponsor and a splendid chap
