Help understanding Krone, 110, LSA+, Keystone?
Old 28-11-2007, 2:01 PM   #1
3,346, Level: 13
Points: 3,346, Level: 13 Points: 3,346, Level: 13 Points: 3,346, Level: 13
I'm looking to buy a Cat5 patch panel + punchdown tool
There are multiple types advertised.
Eg.
It appears that the punchdown tool required for each type is different.
Can someone confirm if this is the case?
Also, for standard RJ45 wall outlets, what type of punchdown tool is required? Can I use the same 110 or Krone punchdown tool as used for the patch panel?
