Thor Scart - Scart, any good
Old 28-11-2007, 12:52 PM   #1
5,978, Level: 18
Points: 5,978, Level: 18 Points: 5,978, Level: 18 Points: 5,978, Level: 18
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 21, Got 18
Thinking of buying a Thor 1.5m scart - scart cable. Can pick one up for under £13 so seems quite good value if they are any good.
Anyone use such a cable?
Old 28-11-2007, 1:47 PM   #2
Illustrious Mumbler
Mr Incredible's Avatar
19,511, Level: 33
Points: 19,511, Level: 33 Points: 19,511, Level: 33 Points: 19,511, Level: 33
Activity: 7.8%
Activity: 7.8% Activity: 7.8% Activity: 7.8%
Thanks: Gave 1,659, Got 3,439
Re: Thor Scart - Scart, any good
I have a Thor Scart and I'm very impressed with the build quaility and picture too! You can't go wrong for £13.
Old 28-11-2007, 3:23 PM   #3
1,863, Level: 10
Points: 1,863, Level: 10 Points: 1,863, Level: 10 Points: 1,863, Level: 10
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 0, Got 13
Yes the Thor Scart cable is a good cable. My only gripe with it, is that it is a heavy and stiff cable which can make plugging it in slightly hard if you're cables have to make a bend near the socket. Other than that,it is probably the best scart lead around £20.00.
Old 28-11-2007, 5:23 PM   #4
5,978, Level: 18
Activity: 1.7%
Cheers guys, off to buy one then tomorrow.
Old 28-11-2007, 7:22 PM   #5
3,141, Level: 13
Points: 3,141, Level: 13 Points: 3,141, Level: 13 Points: 3,141, Level: 13
Thanks: Gave 1, Got 1
Screwfix are selling them for £12.79 just got two.
B&Q sell them for £19.98. Excellent cable.
Old 28-11-2007, 8:21 PM   #6
forrestgump's Avatar
8,069, Level: 21
Points: 8,069, Level: 21 Points: 8,069, Level: 21 Points: 8,069, Level: 21
Thanks: Gave 117, Got 54
they are only stiff when the room is cold! plastic goes softer when the surrounding atmosphere is warmer so the thor will be more flexible when you have had the radiators on for a while, sounds strange but it is true
i have used thors for years and they are th dogs bo...ox
