Short sub cable needed
Old 27-11-2007, 11:35 PM   #1
3,697, Level: 14
Points: 3,697, Level: 14 Points: 3,697, Level: 14 Points: 3,697, Level: 14
Thanks: Gave 5, Got 0
Hi guys,
I am after a 0.75m or 1m sub cable to connect my Kef 1005 sub to my amp.
As it only provides the 'rumble', do I need to spend mega money or will I get away with a half decent one for a tenner or under ???
I have most of my other cables sorted but am struggling to find a reasonably well reviewed sub cable.
Please help !!!!
Cheers, Jobby.
Old 28-11-2007, 2:25 AM   #2
davepuma's Avatar
32,013, Level: 43
Points: 32,013, Level: 43 Points: 32,013, Level: 43 Points: 32,013, Level: 43
Activity: 28.7%
Activity: 28.7% Activity: 28.7% Activity: 28.7%
Thanks: Gave 396, Got 2,176
Re: Short sub cable needed
Take a look at the powerbuy above, there are a few retailers on there that will make cables to specific lengths. I've got some excellent cables made to specific lengths in the past on there. I also recently got some analogue cables from bluejeanscables so can recommend them in addition to the guys in the powerbuy. I did have to pay import duty but it worked out cheap and the cables are excellent quality and delivery was quick. They should be able to knock up a short cable for you.
Old 28-11-2007, 9:07 AM   #3
chrisflak's Avatar
3,505, Level: 13
Points: 3,505, Level: 13 Points: 3,505, Level: 13 Points: 3,505, Level: 13
Thanks: Gave 9, Got 5
For what its worth I bought one on these forums, see link,for my Kef 2005.2 system and the PSW2010 subwoofer with this is awesome. i dont think you can go far wrongwith one of these !
http://www.avforums.com/forums/showt...ght=mark+grant
Old 28-11-2007, 9:09 AM   #4
chrisflak's Avatar
3,505, Level: 13
http://markgrantcables.co.uk/shop/in...&products_id=6
Old 28-11-2007, 9:11 AM   #5
mossym's Avatar
Location: You'd get your feet wet getting here, but the Guinness is worth it...
24,851, Level: 38
Points: 24,851, Level: 38 Points: 24,851, Level: 38 Points: 24,851, Level: 38
Activity: 11.8%
Activity: 11.8% Activity: 11.8% Activity: 11.8%
Thanks: Gave 598, Got 1,310
will recommend bluejeans cables as well. just got a short sub cable from them as well and it is very well made. in ireland but didn't ahve to pay customs, and our laws are as stringent as your with values i think. one cable shouldn't put you over the limit. well worth checking out.
