PC Nedion 6486 to Samsung HT AS710 AMP
Old 27-11-2007, 3:43 PM   #1
2,272, Level: 11
Points: 2,272, Level: 11 Points: 2,272, Level: 11 Points: 2,272, Level: 11
Thanks: Gave 0, Got 2
I have the Medion 6486 PC with 7.1 channel realtek output. I want to connect this to the Samsung HT-AS710
http://downloadcenter.samsung.com/co...9/EN/main.html
Do I need to connect it to the analogue 5.1 inputs and if this is the case what leads to I need or am I completely wrong??
I have been trying to figure it out but am getting nowhere fast so any help much appreciated.
Old 28-11-2007, 2:40 AM   #2
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,177
Re: PC Nedion 6486 to Samsung HT AS710 AMP
Without knowing exactly the type of sound card (is it a separate card or motherboard?) I can't say for sure but if it has the coloured analogue line out connectors, then you will need 3 x 3.5mm to phono leads for 5.1. Clicky
There is a sound card forum, do a search on there for your particular PC to be sure.
