New LCD, Blu-ray player and V+/HD Box = Which cables?!?
Old 27-11-2007, 1:03 PM   #1
9,006, Level: 22
Points: 9,006, Level: 22 Points: 9,006, Level: 22 Points: 9,006, Level: 22
Thanks: Gave 13, Got 10
Question New LCD, Blu-ray player and V+/HD Box = Which cables?!?
Ok ladies & gents, please be gentle on this newbie question!
I've just taken my fist steps into HD by buying a 46" Sony (V3000), Blu-ray player and also upgraded to V+/HD.
With this in mind I have started looking around at various HDMI cables and the price differences are shocking?!?
I'm not wanting to pay the earth, but at the same time I am not wanting to buy any old crap that would ruin the experience of my new equipments capabilities. I looked on amazon but can only find cables for about £10, and the Sony shop wants to sell me cables costing £60 each.
In a month or so I will also be adding some home cinema kit (which will plug into the TV and Blueray player i presume?), therefore a suggestion of the cable I will need for that would be gratefully received to.
What do I buy and in which order do I connect etc?!?
Old 27-11-2007, 1:10 PM   #2
kmark40's Avatar
5,007, Level: 16
Points: 5,007, Level: 16 Points: 5,007, Level: 16 Points: 5,007, Level: 16
Thanks: Gave 165, Got 45
Re: New LCD, Blu-ray player and V+/HD Box = Which cables?!?
As you are using 1080p sources and display, you cant go wrong with the cable of forums member mark grant. they're highly recommended e.g http://markgrantcables.co.uk/shop/in...products_id=99
you could also try
http://markgrantcables.co.uk/shop/in...products_id=99 bluejeans are shipped from the US so anything other £18 in value, could incur a customs charge.
Other may disagree with the above, but this is my opinion.
Old 27-11-2007, 6:13 PM   #3
9,006, Level: 22
you could also try
Thanks for the kmark.
Anybody else got any other options that I could pick up locally in my local indy or Richer sounds etc?
Old 28-11-2007, 3:38 AM   #4
kmark40's Avatar
5,007, Level: 16
i got the link for bluejeans cable wrong. here it is http://www.bluejeanscable.co.uk/store/dvi/index.htm
mark grant is uk based, if i didn't clarify b4
Old 28-11-2007, 12:57 PM   #5
Jamie's Avatar
10,760, Level: 24
Points: 10,760, Level: 24 Points: 10,760, Level: 24 Points: 10,760, Level: 24
Thanks: Gave 93, Got 573
I've yet to be convinced by expensive HDMI cables, for long runs I'd splash more cash but if your kit is all together then I don't see the need in spending too much cash.
I have 2 HDMI cables. 1 was £60 (I was given it so it wasn't my money) and the other was a tenner from fleabay and I honestly can't tell the difference between the 2. One proviso though I'm only using 720p or 1080i from my PS3 Blu Ray I don't have a 1080p display.
General consensus seems to be on this forum that the Mark Grant cables are excellent but cheapy short HDMI does the job.
Old 28-11-2007, 1:19 PM   #6
9,006, Level: 22
Jim, I went to my local Indy (Sevenoaks) at lunchtime and that is exactly what he said as well.
He said that because my kit was going to be together on a stand I was best off buying a 1mtr £45 QED cable for my blu-ray player, and a 1mtr £30 IXOS cable for the Virgin HD box.
Thoughts on that?
Old 29-11-2007, 10:06 AM   #7
kmark40's Avatar
5,007, Level: 16
jimbob my experience was much the same yours until i went 1080p, then using the cheapo cables introduced sparklies. u dont have to pay the earth,but the word 1080p should be a prerequisite when buying
