home cinema speakers to tv cable?
Old 26-11-2007, 8:56 PM   #1
2,839, Level: 12
Points: 2,839, Level: 12 Points: 2,839, Level: 12 Points: 2,839, Level: 12
Thanks: Gave 2, Got 0
Post home cinema speakers to tv cable?
Hi there I am going to be buying a home cinema dvd system this -http://www.amazon.co.uk/Sony-DAV-DZ2.../dp/B000NVWCTS or this - http://www.amazon.co.uk/SAMSUNG-Home...sbs_ce_title_5 .Basically i am wanting to hook up the speakers to the tv so they play whilst watching normal tv not just dvd`s.What cables will i need to enable this?And will the home cinema system be provided with them when i buy or do i need to buy these?
I have a samsung 32" hd tv shown here http://www.directtvs.co.uk/Samsung_3...DX/version.asp If it matters which tv it is?
Help would be welcome
thanks
deonn.
Old 26-11-2007, 10:02 PM   #2
Conspicuous Member
21,528, Level: 35
Points: 21,528, Level: 35 Points: 21,528, Level: 35 Points: 21,528, Level: 35
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 4, Got 1,393
Re: home cinema speakers to tv cable?
The Sony is an utter waste of time, it has one input on the front for STEREO only.
The Samsung is basically a 2.1 stereo system, put does have a optical input for 5.1 input (BUT ONLY ONE) for TV sound you normally need one of these http://www.tvcables.co.uk/cgi-bin/tvcables/PH002.html and fit to a stereo input phono socket.
OR better still get a AV starter system (£220) (Receiver and speakers 5.1) add a HDMI upscaling DVD player (£50) and you will not have input issues they normally come with 2 opticals + 1 coax and 1 5.1 direct in for real surround sound connectivity, + an assortment of stereo inputs.
Old 27-11-2007, 12:15 AM   #3
Jamie's Avatar
10,760, Level: 24
Points: 10,760, Level: 24 Points: 10,760, Level: 24 Points: 10,760, Level: 24
Thanks: Gave 93, Got 573
Agree on the Sony and The Samsung I suspect would be dissapointing.
For £249 you could go for the top option on this page:
http://www.richersounds.com/informat...ecinemasystems
Which would be tonnes better.
Old 27-11-2007, 3:56 PM   #4
2,839, Level: 12
Hi there , i dont really know a lot about what im talking about but..
why is it better? What does the Receiver do? , i was swaying towards the samsung because i could plug my usb pen into it and play music off my mp3 , and i could link the speakers to play normal tv with a phono cable with the samsung x200r system?
thanks.
Old 28-11-2007, 12:34 AM   #5
Jamie's Avatar
10,760, Level: 24
Simply sound quality.
Plus you also have a good upgrade path, maybe a replacement HD-DVD player or Blu ray could be added, maybe an upgrade to better speakers at a later date.
With a 1 box you would have to replace the whole system.
Its very rare to find a system (be it HT or stereo "midi systems") that sounds as good as budget seperates for a similar price.
As you said in your PM if its for a bedroom as a 2nd system then one of the systems you mentioned could be ideal but I stand by my opinion, with your budget (I guess about 250ish) I'd go for the seperates package I mentioned.
