Connection Advice
Old 26-11-2007, 12:32 PM   #1
raven219's Avatar
6,691, Level: 19
Points: 6,691, Level: 19 Points: 6,691, Level: 19 Points: 6,691, Level: 19
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 8, Got 5
Connection Advice
In my office I have an Arcam DVD player that has component, scart and S-Video outputs. I would like to connect it to my PC LCD monitor (Dell 20" widescreen) which has a DVI (in use), VGA, S-Video and Composite inputs.
I have tried the S-Video direct connection but could only get a black and white picture.
Is there anyway I can connect these two and what is the best method?
Old 26-11-2007, 1:24 PM   #2
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,176
Re: Connection Advice
Have you altered the Arcam's video output for S-Video?
If you wanted the best connection type you could get a component to VGA converter from js-technology but TBH, I would try and get the S-Video working, it's a 20" PC monitor after all. Does the PC not have a DVD drive installed? (I know that a lot at my work don't or won't allow DVD playback for obvious reasons. They've even banned youtube etc... Must think we'll all skive and not work...)
