AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Other Home Cinema Essentials > Interconnects, Speaker Cables and Switches
Notices
Quad Lites and biamping Robsk1 Speakers 2 17-10-2007 11:24 AM
Amp for Quad Lites? Darkly AV Amplifiers and Receivers 5 09-10-2007 5:53 PM
appreciate suggestions for an amp for Quad Lites starre AV Amplifiers and Receivers 0 19-05-2007 8:42 PM
Quad lites speaker stands jamie110 Speakers 3 06-09-2006 1:20 PM
bi-wire or not - to Quad Lites mavice Interconnects, Speaker Cables and Switches 4 13-07-2006 6:30 PM
Old 25-11-2007, 9:20 PM   #1 (permalink)
Thanks: Gave 1, Got 2
Speaker Wire for Quad Lites / Onkyo 605
Have the above combination and am thinking of QED Silver Anniversary for the front, QED Original for the rear.
Anyone suggest a better or equal option that would be cheaper? From reading various threads on here can't help thinking I might be getting ripped off!!
Thanks,
garethr_davies is offline   Reply With Quote
Old 26-11-2007, 10:55 AM   #2 (permalink)
Re: Speaker Wire for Quad Lites / Onkyo 605
anyone?
Old 26-11-2007, 11:37 AM   #3 (permalink)
Thanks: Gave 3, Got 46
Thanks,
Silver plating loudspeaker cable conductors is pointless (apart from the extra profit margin to manufacturers and retailers).
Buy the cheapest cable which has an adequately low conductor resistance (less than about 5% of the speakers nominal impedance). Practical factors like colour of insulation, mechanical flexibility, insulation material fire resistance properties, etc. may also need to be considered.
Alan
Studer B225 CD player - Pioneer VSX-LX70 - Quad 405-2 amplifier + ESL 63 electrostatics (front) - A.G. A'Diva x 4 (surround).
Humax HDCI-2000 HDTV satellite receiver - Yamakawa 365 DVD - Sony BDP-S300 BD - JVC DLA-HD1 projector - Beamax frame screen, 1650 mm x 930 mm - Harmony One remote.
Alan Mac is offline   Reply With Quote
Old 26-11-2007, 5:28 PM   #4 (permalink)
Thanks Alan, please can you suggest a particular wire?
Old 26-11-2007, 5:36 PM   #5 (permalink)
How about this?
http://cgi.ebay.co.uk/189-Strand-OXY...QQcmdZViewItem
Old 26-11-2007, 5:49 PM   #6 (permalink)
Hi Garethr,
I can’t find any mention of the resistance per metre, but yes, it looks as if it ought to be OK.
Alan
605, lites, onkyo, quad, speaker, wire
