AVForums - Free Audio Visual electronics advice and information
AVForums.com twitter page AVForums.com facebook page AVForums is a member of CEDIA. THX certified reviewer.  Click for more information. AVForums reviewers are ISF Certified.  Click for more information.
Forum List Register Blogs Information Social Groups Search Today's Posts Mark Forums Read
Go Back   AVForums.com > Forums > Other Home Cinema Components > Interconnects, Speaker Cables and Switches
Home Cinema Podcast
Fri, 16 Jul 2010
Play Home Cinema Podcast : 16th July 2010
We discuss the TVs recently reviewed, including Sharp Quattron and 3D TV.
 Duration 48:33
Latest AVForums Hardware Reviews
Panasonic VT20 (TX-P65VT20B) ReviewAcoustic Energy Aegis Neo V2 Series ReviewLG 15 inch OLED TV (15EL9500) ReviewPhilips 7000 series LED (37PFL7605) Review
Movies Podcast
Fri, 16 Jul 2010
Play AVForums Movies Podcast : 16th Jul 2010
We talk about the latest Blu-ray news.
 Duration 1:00:11
Latest AVForums Movie Reviews
Lock Up Blu-ray ReviewThe Prowler Blu-ray ReviewGalaxy of Terror Blu-ray ReviewBounty Hunter, The Blu-ray ReviewHachi: A Dog's Tale Blu-ray ReviewForbidden World Blu-ray Review
LinkBack Thread Tools
Old 25-10-2007, 1:25 PM   #1
Dr Force's Avatar
Thanks: Gave 501, Got 293
CAT 5 Cable, whats its purpose
Hi guys
I hear alot about people using cat5 cable but what is it best used for ie is it better to use this as a BT cable, door entry,pc etc,etc??
Also what are the advantages of using it in HC applications?
MY HOME CINEMA
MY KIT:Mits HC6000 1080PJ,Hitachi 42PD7200,92" Grandview Screen,Sony STR3200ES,SVS 5.0,Wharfedale SW150 Sub,
ToshHD E1,ToshHD EP-30, HD DVD Add On,Sky HD & Xbox 360.
Dr Force is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on Twitter
Old 25-10-2007, 1:59 PM   #2
youngsyp's Avatar
Thanks: Gave 80, Got 213
Re: CAT 5 Cable, whats its purpose
Cat 5/ ethernet/ patch cables are what you might use to connect your PC to a router or you might use them as a connection medium between a server and network port etc...
The easiest way to describe them is they're data cables that look like large phone (RJ45) cables, just with more contact points on the plugs.
In a home cinema capacity, you may use them to plug your ethernet port equipped amplifier/receiver, into your home network, so it can recieve online updates. Of course, they can also be used to connect a HTPC to your home network.
Hope this helps.
youngsyp is offline
Dr Force (25-10-2007)
Old 25-10-2007, 2:12 PM   #3
Thanks: Gave 16, Got 146
They are also used with ballons to conect up bits of gear. The balons convert your input signal. i.e component video, into cat5 and then has another balon on the end to convert it back to component. Its useful because you can have long distances of cable that are very cheep to replace. they take up a small amount of room compared to most HC cables and they are well shielded due to their data origins.
http://www.svideo.com/1080i.html
Para is offline
Old 25-10-2007, 2:17 PM   #4
have a look at this
http://lib.store.yahoo.net/lib/videoware/500050.swf
Para is offline
Old 25-10-2007, 3:13 PM   #5
Conspicuous Member
Thanks: Gave 54, Got 692
Basically any office with PC's will have them all connected to the network via cat5 (or better ie cat6 etc) so the PC's can talk to each other, servers, printers etc etc etc. Just about all the equipment in the office can use this cabling, even modern IP Telehpones via bunch of network equipemnt such as routers, switches, patch panels. This will also be the way any office PC connects to the internet and e-mail.
As already explained cat 5 cable is very cheap to install. So in a HC you can use it to pipe AV around the home without spending a fortune on ever changing cabling requirements.
A better idea of what you can do with cat5 can be seen by looking at the baluns you can buy to convert your AV signals. Have a look Here for some examples. They are not cheap, but probably cheaper than wiring up loads of different cables throughout a house.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Dune BD Prime 3.0 > Lumagen VisionHDP > Panasonic TH-46PZ85B.
Marantz RC9200
MarkE19 is offline
cable, cat, purpose
Optimised for Firefox
AVForums.com is owned and operated by M2N Limited
Copyright © 2000-2010 M2N E. & O. E.
