Hi Paul,
i think the davs 800 has a optical output
You're getting mixed up a little here...
Yes I am thinking that you could connect a new dvd player to the DAV800 so you'd need an optical* input on the dav800 (not an output).
You wouldn't have to connect both analog and digital audio to the dav800 but it won't do any harm. You do need to connect the optical* output of the new dvd player to the dav800 to get the dolby digital (or dts) bitstream into the dav800 (so you can enjoy surround sound).
Yes, you could try (or just use) your Toshiba instead of a new player.
Connect the rgb output of the dvd player to the tv (fully wired scart to scart) and connect the optical* audio output to the dav800. The rgb scart connection will also carry stereo audio to the tv but for full Dolby Digital you'll need the connection to the DD processor in the dav800. (Don't forget to turn down the sound on your tv when using the audio from the dav800**)
To connect to the side s-video port, you'll just need a standard s-video lead which you can pick up in Currys, Comet, Maplin or any tv dealers.
You should be able to source an optical lead from a similar store.
Component video is similar to rgb and will give you a similar picture quality. However, component and rgb aren't the same, so you can't mix them together. Component video is carried on 3 phono connectors which are coloured red, green and blue. If your dav800 has these (sounds as if it hasn't) then that would be the best connection to your tv. If your Toshiba has these then, that (or rgb via scart) will be the best connection to the tv.
(* I assume that the dav800 actually has an optical input. It is just possible that it might also have a co-axial digital input. If it has, and assuming that your dvd player also has a coaxial digital output, then you could use that instead of the optical connection. It's usually a single phono socket coloured 'orange' and should be labelled accordingly. If you have one of these you can use a phono to phono video lead (usually coloured yellow) to carry the signal_ OK, you could argue that a proper digital lead will do a better job but this would get you going)
(**Check to see if your tv has an optical OUTPUT. If it has then you can get the tv sound into the dav800. You'd then use Dolby ProLogic to get "surround" from broadcast tv programmes)
hope that helps,
Brian
