What Cable?!!
Old 19-06-2007, 5:12 PM   #1
Thanks: Gave 0, Got 6
What Cable?!!
I have a xbox 360 system with my htp gs1 xbox 5.1 system. 1 lead from xbox 360 to the 5.1.
there are 2 inputs so can i put 1 in to my virgin + hd box and get surround sound?
what if i want 5.1 from my dvd player is that possible what do i need?!!
Old 19-06-2007, 6:22 PM   #2
davepuma's Avatar
32,005, Level: 43
Points: 32,005, Level: 43 Points: 32,005, Level: 43 Points: 32,005, Level: 43
Activity: 34.1%
Activity: 34.1% Activity: 34.1% Activity: 34.1%
Thanks: Gave 396, Got 2,176
Re: What Cable?!!
Yes run another optical cable from your v+ box for DD 5.1 s/s. If your DVD player only has optical outputs, you could use an optical splitter to share one of the inputs. Alternatively you could use an optical to co-ax converter (with one of each cable). If the DVD player has co-ax out (it's a RCA connection and usually coloured orange, I think) use a co-ax cable. Try Profigold , they're cheap and well built for the price.
