10m scart with sky?
Old 17-06-2007, 3:02 PM   #1
delpr
Posts: n/a
10m scart with sky?
Hi, I have just bought a samsung LE26R87BD for the kitchen and want to connect it to a sky receiver in the bedroom.I recon the length would be around 7-8m.Can someone please tell me the best way to connect and what make of cables i should use. Thanks.
Old 19-06-2007, 1:53 PM   #2
12,548, Level: 26
Points: 12,548, Level: 26 Points: 12,548, Level: 26 Points: 12,548, Level: 26
Thanks: Gave 13, Got 372
Re: 10m scart with sky?
You should be fine with a "flat ribbon" like the one on this page:
http://www.satcure.com/accs/page4.htm#scarts
It's HEAVY to post so maybe you could pick one up locally.
Old 19-06-2007, 3:31 PM   #3
3,350, Level: 13
Points: 3,350, Level: 13 Points: 3,350, Level: 13 Points: 3,350, Level: 13
Hi.
I use profigold 10m SCART cables - I find them excellent, not that expensive (£50 for a 10m cable).
I have no probs runnning a Sky Digibox on a 15m version of this cable, so 10m would give you no probs at all
Old 19-06-2007, 4:14 PM   #4
Conspicuous Member
AnthonyG's Avatar
25,381, Level: 38
Points: 25,381, Level: 38 Points: 25,381, Level: 38 Points: 25,381, Level: 38
Activity: 21.3%
Activity: 21.3% Activity: 21.3% Activity: 21.3%
Thanks: Gave 1,186, Got 1,013
I have tried a couple of bog standard 10m Scart Leads.
One that was normal type scart, and the other which was a composite lead that attached to a scart adapter at the end.
The PQ on both was absolutely terrible.
The macro blocking was present on a 14" CRT TV. On a 32" LCD the PQ would likely be unwatchable.
The way I have my Sky fixed up now is by a High Quality 6m Belkin Aerial Cable.
This cable is much thinner than a Scart Cable and due to the small Aerial tip it can be drilled through walls to make the needed length smaller.
However if Scart is a neccessity. Which I have not tried their Scart leads. I have tried Profigolds 5m VGA cable and the quality is superb.
I would therefore recommend either these or a Scart lead by QED for this purpose.
