is this cable any good?
Old 29-03-2007, 2:19 PM   #1
masterwai
Posts: n/a
anybody know if this cable s any good?
http://www.lidl.co.uk/uk/home.nsf/pa...Cable_-_2m.ar8
thanks
Old 30-03-2007, 11:33 AM   #2
1,863, Level: 10
Points: 1,863, Level: 10 Points: 1,863, Level: 10 Points: 1,863, Level: 10
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 0, Got 13
Re: is this cable any good?
Well for £4.99 even it is a load of rubbish you haven't lost a vast sum of money, although if you decide to go for one, ask in-store whether you can return it if you are not entirely satisfied with it. Just one other thing for £4.99 don't expect the best quality in the world, alternatively I think play.com do a good priced lead at £10.00 all in and 2.4m so is a handy length and I am sure Ixos do a lead around about £20.00 now. What kit do you have by the way?, if its a budget dvd player and hdtv screen then an inexpensive lead will be fine, however if its a step up from budget kit ie midrange sony, toshiba, it would probably be worth spending a little more say up to £20.00-£30.00
