Hi Guys,
Sorry if this is a totally noddy question but.....
I'm bi-amping my whole set up. Currently got simple single runs of that £2.50 a metre Audio Innovations Ultra Micro stuff from Richer sounds. Nothing is currently bi-wired or bi-amped so the jumpers are still in place on the back of the speakers etc. etc.
I'm about to buy a second 5 channel amp. Easiest and cheapest option is to simply buy another load of this cable for additional runs to all 5 speakers, BUT...could I also use a 4 core bi-wire speaker cable (or any bi-wire speaker cable for that matter) to
bi-amp the speakers with.....
E.G. Van den Hul Black series? I am assuming you can do this,
BUT - does the actual bi-amping part of the equation mean you should use two seperate runs to avoid any potential interference / gain a little more quality? OR... am I talking rubbish and a 4 core VDH cable / bi-wire cable etc. will do the job fine and also save me a bit of visable mess with SWMBO?
Sorry again if this is a dummy question.......
Kit is Monitor Audio RS5's all round, RS centre with 2 X Rotel RMB 1075 amp's (hopefully) and Rotel RSP 1068 processor. All of this kit is regarded as being on the brighter side of neutral, and I was just wondering if using a silver plated cable, such as sticking with the Audio Innovations stuff, or buying QED SA XT, or even Monitor Audio's own Pureflow cable......would that add even more brightness and make the system fatiguing over long listening periods?
The system will be used for music as well as movies in the short term (until the pure hi-fi set-up I'm working on is put together anyway), and whilst I don't mind a bright sounding set-up for AV, I do prefer a warmer sound on music....
I'm fully aware that a cable will not make a significant difference......
But any suggestions for a cheapish 'warm' sounding cable that will maybe take the "edge" off the above components sound.....would be greatfully appreciated.
Not looking to spend the earth either....say around £5 per metre budget as I will need almost 50 metres if I end up re-doing the whole lot.
VDH Blue and Black series seem to be well liked and are cheap enough - are they a warmer sounding cable generally than the ones mentioned above?
Cheers and Many thanks in advance,
David.
