Scart RGB....good quality one?
Old 28-03-2007, 11:56 AM   #1
xulak1
Posts: n/a
Hi i am soon upgrading my screen to a 1080p!
but i need to conect it to a digital cable box....which only has an rgb scart output. Can you guys quote me a good e-bay scart (gold plated, no interference and maybe oxygyn free kinf od gimics?) seller i can buy off from e-bay?
Any sugegstions on what to look for and not waste money on? ohh....is component better than scart?
regards, Jame,s
Old 29-03-2007, 1:32 PM   #2
ipace's Avatar
2,181, Level: 10
Points: 2,181, Level: 10 Points: 2,181, Level: 10 Points: 2,181, Level: 10
Thanks: Gave 44, Got 16
Re: Scart RGB....good quality one?
regards, Jame,s
Hi Xulak ,
Component is better then scart however the melita digital cable box is not capable to outputting component output. the best results i got where using a scart to scart cable which i got from doneo, if you want i can check what the brand is for you....it was around Lm10.
Ian
Old 29-03-2007, 1:35 PM   #3
xulak1
Posts: n/a
Originally Posted by ipace View Post
Hi Xulak ,
Ian
Hey, thanks mate. ant idea if yours is an RGB scart?
Old 29-03-2007, 6:31 PM   #4
3,203, Level: 13
Points: 3,203, Level: 13 Points: 3,203, Level: 13 Points: 3,203, Level: 13
Thanks: Gave 4, Got 0
Check this site out, products and service right on the money
http://www.markgrantcables.co.uk/
