Home Brew Advice
Old 26-03-2007, 2:14 PM   #1
lunker's Avatar
5,869, Level: 18
Points: 5,869, Level: 18 Points: 5,869, Level: 18 Points: 5,869, Level: 18
Thanks: Gave 12, Got 10
Home Brew Advice
I’m having a final push on putting the “finishing touches” to my home cinema. I currently use standard 1M cables for Digital Coax which I coil up to keep things neater.
As the DVD is only about 10cm away from the AMP I’m looking to get shorter cables but the shortest I can find are 0.5M. This is still a lot longer than I need so I’m going to make my own.
To cut a long story short will these be OK to make a 10cm Digital Coax?
Connectors
http://www.maplin.co.uk/module.aspx?...26m3#more_info
Cable
What would the quality be like compared to a Mark Grant equivalent?
Old 26-03-2007, 4:35 PM   #2
5,152, Level: 17
Points: 5,152, Level: 17 Points: 5,152, Level: 17 Points: 5,152, Level: 17
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Thanks: Gave 11, Got 12
Re: Home Brew Advice
For such a short length of cable I think you would be hard pushed to tell the difference between any cable.
The items you linked to will work fine.
lunker (26-03-2007)
Old 26-03-2007, 4:58 PM   #3
lunker's Avatar
5,869, Level: 18
Cheers phils_wicked.
I've just got to dust off my soldering iron.
Old 26-03-2007, 8:37 PM   #4
Illustrious Mumbler
Mr Incredible's Avatar
19,513, Level: 33
Points: 19,513, Level: 33 Points: 19,513, Level: 33 Points: 19,513, Level: 33
Activity: 7.8%
Activity: 7.8% Activity: 7.8% Activity: 7.8%
Thanks: Gave 1,659, Got 3,440
I wouldn't make it soo short as the curvature of the shorter cable may place extra stress on your phono sockets. Besides, Belden 1694A coax cable has a minimum bend radius specification of 7cm.
Old 27-03-2007, 6:49 AM   #5
lunker's Avatar
5,869, Level: 18
Thanks for the tips I'll have to take your word about the minimum bend radius specification of 7cm as I can't for the life of me find that any where on the page.
I'm going for 10cm> so I should be OK.
Old 27-03-2007, 8:19 AM   #6
Illustrious Mumbler
19,513, Level: 33
Activity: 7.8%
Search for "bend" and find 2.75" (7cm)!
It is 7cm RADIUS, so any cable configured in a semi-circular "loop" will have a minimum diameter of 14cm, which is wider than your 10cm between the phonos.
EDIT.
A quick layout suggests a 500mm cable won't be too far off the optimal length.
Circumference of a 14cm circle is Pi x D = +/- 44cm, so add a bit for luck and there you have it!
Old 27-03-2007, 9:30 AM   #7
Illustrious Mumbler
19,513, Level: 33
Activity: 7.8%
I just found a nice plugin for Corel which calculates the length of a curve. The example above: the red line is 464mm long. TBH for a hassle free life and guaranteed quality, I'd buy a 500mm one!
Old 28-03-2007, 2:48 PM   #8
lunker's Avatar
5,869, Level: 18
Thanks for the comprehensive reply Malice.
I had already purchased the cable by the time I’d read the post. As I had to buy a meter of cable I made a 44cm one. I had fun making it any way and it sounds to my ears as good as the 1M one I was using before.
I’m going to have to look at cable management in the new AV unit.
