Component from a Sky Box via a Monster Converter
Old 26-03-2007, 9:59 AM   #1
Monster_2003
Posts: n/a
Hi All,
I wonder if you can help, I have a Sony Bravia 32V2000 linked with component in AV3 and HDMI in AV4 running down to a Sony STR-DG700
The DVD player is working fine through HDMI and all the sound is coming through no hassles. However, I have my sky box connected via Video 2 with a Monster Scart to Component Converter at the Sky end and Component going into the Amp. The sound is coming through fine from two seperate phono plugs when Video 2 is selected as source but no vision.
I am not sure if I am being thick. I have tested the converter and the component lead and all seems okay.
Am I missing something simple?
Thanks in advance
Alan
Old 26-03-2007, 11:15 AM   #2
gerbilly's Avatar
11,727, Level: 25
Points: 11,727, Level: 25 Points: 11,727, Level: 25 Points: 11,727, Level: 25
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 40, Got 82
Re: Component from a Sky Box via a Monster Converter
Originally Posted by Monster_2003 View Post
Hi All,
Thanks in advance
Alan
Im not sure but I dont think you will get a picture that way. You will either have to connect via scart or upgrade to Sky HD and use the component connection there.
Old 26-03-2007, 4:36 PM   #3
Assured Advertiser
Joe Fernand's Avatar
36,547, Level: 46
Points: 36,547, Level: 46 Points: 36,547, Level: 46 Points: 36,547, Level: 46
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 205, Got 1,344
Hello Monster_2003
Your 'Converter' is actually a passive 'Adapter' - it relies on your Source device having the ability to Output YUV 'Component' on its SCART socket; which is not an option with SKY or SKY+.
You require an RGB2YUV converter that is mains powered and includes active signal processing - see http://www.js-technology.com/product...1af53b6c72926f
If you have SKY+ you could revert to S-Video Out and let your AV Receiver do its 'conversion' tricks.
Best regards
Joe
Old 27-03-2007, 4:54 PM   #4
4,312, Level: 15
Points: 4,312, Level: 15 Points: 4,312, Level: 15 Points: 4,312, Level: 15
Thanks: Gave 223, Got 63
Would this do the trick?
http://www.futureshop.co.uk/qed-scar...tor-p-399.html
AnilS.
Old 27-03-2007, 6:20 PM   #5
Assured Advertiser
36,547, Level: 46
Activity: 20.9%
Hello AnilS
Yes the CYP CSY2100 (QED re-badge it) is a lower cost option - its good value if not quite as good as the JS-Technology unit; though the difference may not be so apparent on a smaller Display.
See http://www.cypress.com.tw/product.ph...rocessors&SR=0
Joe
