I've run out of optical inputs...what can I do?
Old 26-03-2007, 6:14 AM   #1
14,866, Level: 29
Points: 14,866, Level: 29 Points: 14,866, Level: 29 Points: 14,866, Level: 29
Activity: 18.6%
Activity: 18.6% Activity: 18.6% Activity: 18.6%
Thanks: Gave 419, Got 115
I have three optical inputs on my amp and all are used. I need to run another optical input through it though and dont want to keep swapping leads. Is there an 'optical splitter' of some kind that will allow two inputs into one optical input?
Old 26-03-2007, 7:21 AM   #2
5,545, Level: 17
Points: 5,545, Level: 17 Points: 5,545, Level: 17 Points: 5,545, Level: 17
Activity: 3.9%
Activity: 3.9% Activity: 3.9% Activity: 3.9%
Thanks: Gave 73, Got 209
Re: I've run out of optical inputs...what can I do?
A splitter is something which splits a single source to feed multiple destinations. To select from multiple sources you need a switch. Something like this
regards
Brian
leamspaceman (27-03-2007)
Old 26-03-2007, 7:53 AM   #3
Conspicuous Member
21,528, Level: 35
Points: 21,528, Level: 35 Points: 21,528, Level: 35 Points: 21,528, Level: 35
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 4, Got 1,393
The Samsung DVD can be fed via Co-ax to get 5.1, does this help, assuming your Yamaha can handle 4 5.1 inputs.
Old 27-03-2007, 7:23 PM   #4
14,866, Level: 29
Activity: 18.6%
Thanks for those replies guys
bsuttie
The item you've linked to, is that something that switches three inputs to one destination? From the description it seems to say it switches one input to three destinations?
Andy98765
I'm using coax with my Samsung. My three optical inputs on my amp are taken up with optical out from my TV, optical out from my Pace Twin PVR and optical out from my 360.
Ideally, I'd like something that 'auto-switches' or at least is remote activated.
Old 27-03-2007, 9:40 PM   #5
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,177
Try one of these
leamspaceman (28-03-2007)
Old 28-03-2007, 1:29 AM   #6
2,659, Level: 12
Points: 2,659, Level: 12 Points: 2,659, Level: 12 Points: 2,659, Level: 12
Thanks: Gave 41, Got 15
I have a switcher, i think its 3 to 1, i got it when i brought some other kit but dont have a use for it, you could have it cheap if you want?
Old 28-03-2007, 10:06 AM   #7
14,866, Level: 29
Activity: 18.6%
davepuma
Again, that's a device that allows one input to go to two destinations. I'm after a device that will allow two devices to share one input on my amp. For instance...Xbox 360 optical out and PS3 optical out BOTH to go to ONE input on my amp.
smanaton
Will pm you about this.
Old 28-03-2007, 10:15 AM   #8
davepuma's Avatar
32,020, Level: 43
Activity: 29.7%
Originally Posted by leamspaceman View Post
davepuma
smanaton
An optical signal (like most signals) passes down the cable. As long as the 'channel' is open, the light will get through, so you can use that device both ways AFAIK. You have to ensure that only one source is on at a time. You do get optical splitter boxes for £30 or so and the THOR HDMI box also has digital audio, so that might be a reasonably futureproof upgrade. Plenty of folks have used those devices I posted with good results.
Old 28-03-2007, 10:36 AM   #9
2,659, Level: 12
PM Sent
I also have an optical repeater if your interested?
Old 30-03-2007, 9:32 PM   #10
DolbyDan's Avatar
6,409, Level: 19
Points: 6,409, Level: 19 Points: 6,409, Level: 19 Points: 6,409, Level: 19
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 30, Got 66
Originally Posted by davepuma View Post
Try one of these
I'll back this one, It works both ways.
