From usenet, I've yet to find an archived copy of the page cited:
Subject: Krueger and Nousaine Beaten With a Coat Hanger!
Newsgroups: rec.audio.opinion
View: Complete Thread (10 articles) | Original Format
Date: 2000-12-24 03:18:21 PST
Looks like someone beat Tom Nousaine and I to the punch with a Coat Hanger wire listening test. ;-)
Please see
http://www.magnani.net/~al/DigitalWireLabTest.html :
"So just to recap this thing to death, we had: The professional Sony S7000TP reference DVD player, going to a 20 year old, ugly green, RCA patch cord which was cut in two. On one side of the green RCA I soldered a blue painted wire hanger to the shield and another to the center conductor. I soldered the other ends of the wire hangers to the other half of the ugly green RCA patch cord. We then clipped the alligator clips with thin wire to the centers and shields of the RCA connectors of my cable and of the Canare cable, and then plugged the other XLR-balanced side of the Canare into the Dolby Labs decoder. I honestly did not know how badly we would be rolling errors on this one... and with open, scientific minds, we played a DVD... "
Obviously, this guy cheated. No rust on the wire! ;-)
"Are you all sitting down? Good. We played the King Crimson Deja VROOM DVD for over fifteen minutes with this configuration and not only did it sound good, but the Dolby Decoder reported ZERO errors... Did you all get that ok? ZERO, nadda, nihil, zippo, nothing, none... error-free. Given that, there was not much point in trying the higher quality cables I had brought with me."
"Conclusion: IT DOES NOT MATTER WHAT YOU USE FOR YOUR DIGITAL CABLE CONNECTION BETWEEN YOUR DVD PLAYER AND YOUR PROCESSOR... YOU CAN BASICALLY USE ANYTHING THAT LOOKS ELECTRICALLY LIKE METAL. IT WILL WORK JUST FINE. (Between the coax connectors that is... I have not successfully used the wire hangers on the tos-link optical connectors... yet...) If you like you can hook the shield on one side to one of your Rodan bronze statues, and the other shield to somewhere else on the statue, and then hook the center conductors to another Rodan bronze, and it will work JUST FINE. The sonic clarity will be stunning, as well as visually pleasing."
Obviously, it was the blue paint!
