Go Back   AVForums.com > Other Home Cinema Essentials > Interconnects, Speaker Cables and Switches
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Old 09-07-2006, 10:02 PM   #1 (permalink)
mavice's Avatar
Thanks: Gave 13, Got 20
Question bi-wire or not - to Quad Lites
Anone have any recommendations for cables (make, type, manuf) to wire quad lites from a deon 3806 amp
firstly - should I bother bi-wiring or not ??
I must admit, I did notice an improvement when I bi-wired my stereo speakers.
thanks in advance
Panny PHD9 & AX100 for the big events on SkyHD
Denon 3805 for the film, Audiolab 8000CD & 8000S for the pure musik
Quad Lite system & Sub
And a MMUK screen in silver
mavice is offline   Reply With Quote
Old 10-07-2006, 6:13 AM   #2 (permalink)
clockworks's Avatar
Thanks: Gave 64, Got 272
I'm using QED Micro Bi-wire with my fronts. Haven't bothered with the rears (1.5mm T&E). I admit that I chose it for it's looks and price, but it works well!
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 885, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac Aluminium
clockworks is offline   Reply With Quote
mavice (10-07-2006)
Old 10-07-2006, 9:39 AM   #3 (permalink)
Thanks: Gave 0, Got 2
Bi-wired the fronts and centre with QED Silver Aniversary and single wired the rears. All fitted with QED fitted Airloc bananas by my supplier. Also puchased a QED sub-woofer cable. All cables made up by Hificables.co.uk who provided a great service.
mutley1 is offline   Reply With Quote
mavice (10-07-2006)
Old 12-07-2006, 3:24 PM   #4 (permalink)
AVF Hardware Reviewer
Russell.Williams's Avatar
Thanks: Gave 535, Got 1,125
I won't go over the same old ground about the relitive merits of bi-wiring - it's been discussed to death. Suffice it to say that most of the difference (if there is any) comes from removing the metal links on the speakers and doubling the cable cross-sectional area, than the act of biwiring per se.
But I've just noticed you have a 3805 and are not using channels 6 & 7, according to your signature. With the same cables as bi-wiring you can bi-amp. This DOES make a difference especially at higher volume levels. You are not doubling the power to each speaker as the treble unit draws far less power than the mid bass. You ARE separating the drive units from influencing each others output in a way that bi-wiring does not, inspite of the claims. As the levels increase the treble doesn't harden up anything like so soon, which is a lot less fatiguing, never mind the increased sense of control to the overall sound.
Basically you set the rear speaker to outputs to Zone 3 and make sure the speaker levels are matched. It is worth noting, that in the USA where this has been popular, some hum problems have been experienced by some and not by others. The other draw back is that your room equalisation no longer works as Zone 3 is not affected by the 3805s EQ. There are dodges, but I'll only go into it if you're interested. If you're going to buy two runs of cable it's got to be worth a punt. Do a search on Audioholics.com, there was quite a lengthy article about doing it.
As for which cables, try Van Damme Blue Studio series 2x2.5mm. £1.99/m from Maplins. I've just replaced ALL of my QED Silver Anniversary with it, and it is a much sweeter sounding cable, without any of the QEDs over emphasis of sibilance. I wish I'd found it ages ago - I could have saved myself a small mint. Remember I'm not speculating, this is actual experience from the last week.
FWIW, I've got 2 runs of 6m (I over bought ) on Ebay at the moment. The QED SA sold for enough to mean the VD cost me nothing - result!
Russell
My grandfather imparted some sound advice on his death bed. "Always get good speakers" he said.
DIY Subwoofer Build. HT Piccies.
Russell.Williams is offline   Reply With Quote
Old 13-07-2006, 6:30 PM   #5 (permalink)
mavice's Avatar
thanks russ
I have silver aniversary to my fronts at the mo and you are right that it is quite bright.
I will take a look at the maplin cables.
As to the merits of Bi-wiring, I might be able to bi-amp anyway with my audiolab amp in power mode so no probs there. I did notice a significant difference bi-wiring my Rogers speakers and have never gone back. Bi-amping may give even more improvement as you say
cheers
biwire, lites, quad
