High speed cables are pin for pin compatible with Standard cables, but uses different internal cable types to enable better transmission of certain signals. The main issues come in electrically noisey areas where the better common mode rejection of the High Speed cables helps.
I'm sorry but thats not true at all.
That would suggest that a differently manufactured cable would be needed to pass the high speed test , and that is not correct.
High speed and Standard speed markings are simply the results of a suite of tests done on a sample from any manufacturing line.
Cables are not designed to pass either standard or high speed tests. Should a sample fail, the manufacturer may tweak the process to get a pass , but the tests do not specify anything about the cable manufacturing process or the materials used , only the electrical tests it has to pass to get the grade.
The suite of tests for each grade cut off at very specific points on the bandwidth spectrum , thats all.
Suite 1 or the standard speed test is way way cheaper that the high speed test. So this suite is the one that gets done the most. If it passes , it in no way says that it wont pass the high speed test , in fact most will if the manufacturer would be willing to spend the money to have the tests done , but as this runs into millions in some cases , they simply wont do it.
No manufacturer will run both suites of tests on any single cable , its either one or the other because the cost for both is prohibitively expensive.
A high speed pass means the cable will be guaranteed to pass the higher bandwidth signals , thats all , it specifies bandwidth tests done on a sample from the line only , it does not specify in any way shape or form , what way the cable is made.
Summing up , most cables that pass the standard speed test will indeed pass the high speed test as well , only with long cables ( 8 meters + ) do you get issues with cables not passing higher speed content , and no cable that long will pass the high speed test in any case , you need to go active for that.
Most will certainly pass the 3D blu ray content out there at the moment , which is the second most extreme signal it will be asked to handle. The Highest bandwidth signal your likely to come across any time soon is 2D 1080p at 60fps.
Thats because 3D at 1080p x 24fps x 2 is less bandwidth than 2D 1080p at 60fps . Both of these signal types are at the very start of the high speed test suite , the vast majority of the high speed tests are for future formats that dont exist yet for the home market , suchs as 2K and 4K content.
It is highly unlikely that any cable that passes the standard speed test could not go that tiny bit extra to pass the first two formats of the high speed test.
