Not all of these units work the same way ,
HDMI is 19 pins , the pin out is here on the right ,
HDMI - Wikipedia, the free encyclopedia
Note each TMDS pair has a shield connection , now , two runs of CAT5/6 cable has 4 twisted pairs in each cable , thats only 16 wires , meaning that most of these units work by eliminating the shield connection between the TMDS pairs , some even split one of the TMDS pairs over separate twisted pairs in the cat5/6 cable , meaning any description of signal being still balanced as defined by the HDMI spec is tenuous at best.
The signal needs all the help it can get when being sent over these cables , shielded is best.
The vast majority of these units highly recommend shielded cables , see here for a quite blatant example .... they cant say it enough , and for good reason.
Neet® - HDMI Super Extender over Cat5 / Cat5e / Cat6: Amazon.co.uk: Electronics
Quote :
Extends HDMI signal range up to 100m (480p / 1080i) or 60m (1080p Full HD) using flexible Cat5e or Cat6 network cable to substitute HDMI cable to achieve long distance transmission ** NOTE ** : SHIELDED Cat5e or Cat6 cable is highly recommended for best results.
Simple plug & play operation with auto-adjustment of feedback, equalization and signal amplification... Ultra compact size for ease of in-line installation
Transmission range using Cat6 Cable : 60m for 1080p (and 720p) ... *** PLEASE NOTE : SHIELDED CAT5e or CAT6 Cables are highly recommended )
Transmition range using Cat5e/6 Cable: 100m for 480p (and interlaced resolutions eg: 1080i (Sky HD)) ... Also compatible with Sky HD 3D ... *** PLEASE NOTE : SHIELDED CAT5e or CAT6 Cables are highly recommended )
HDMI certified / ATC tested / RoHS compliant / FCC and CE approved - HDCP Compliant - IEEE-568B Standard - Size: 45x 25x 81mm - 5V DC adapter (for receiver) included (UK Spec) *** Specialist NEET customer support and LIFETIME WARRANTY ***
OP , Shielded cables dont cost much more than you have , Ive seen many many of these units perform fine once you use shielded cable , its worth a shot.
If that doesnt work , you should know that HDMI sockets are not designed in the same way as USB sockets and were never designed to power external devices , your units must get power from somewhere , so they are stealing it from the interfaces of the devices they are connected too , that could also be your problem , trying shielded cables is the cheapest first option.
