Problem when trying to connect two LCD TVs with Ferguson AV3030 transmitter
Old 18-11-2009, 10:27 PM   #1
1,606, Level: 9
Points: 1,606, Level: 9 Points: 1,606, Level: 9 Points: 1,606, Level: 9
I have an LG 32" LCD TV downstairs and a Samsung 32" LCD TV upstairs in the bedroom. Before i had the LG, i used the samsung downstairs and had an old style TV upstairs and used a Ferguson AV3030 as a transmitter so i could watch sky in the bedroom. Everything worked fine, i had a great picture and could change channels no problem.
Since i moved the Samsung upstairs and put the LG in downstairs, the transmitter doesn't seem to be working. I can't get a picture upstairs at all.
Can anyone help? i'm connecting the Scart's the same way i did before.
Old 18-11-2009, 11:36 PM   #2
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
Where are you connecting the transmitter?
If it is directly from your Sky box then it should work.
If you are connecting it to the TV downstairs then do check that the SCART you are using is actually an output as some can be input only.
Old 19-11-2009, 6:33 PM   #3
1,606, Level: 9
I am connecting it directly from the sky box. Its very odd as it has only stopped working since changing the TVs around...
