Aerial modular socket
Old 17-11-2009, 11:23 AM   #1
lagigolo's Avatar
2,177, Level: 10
Points: 2,177, Level: 10 Points: 2,177, Level: 10 Points: 2,177, Level: 10
Thanks: Gave 13, Got 3
I have been running cat 5 sockets in pairs except the front room where at the moment i have gone for 4.
I have double faceplates which are the modular clip in type. Last minute decision i had already run a coax for tv output but pushed a cat 5 through so now would like to change one of the cat5's for a standard aerial socket. But still keeping the same faceplate so it matches.
Can i get the bit i require anywhere???
Old 28-11-2009, 10:21 AM   #2
lagigolo's Avatar
2,177, Level: 10
Just incase anybody else is looking to do the same thing. I finally found somewhere that does different modules, tv, satellite, etc.
TV Coaxial Outlet Module - Female - Screened - White
Old 28-11-2009, 9:19 PM   #3
2,760, Level: 12
Points: 2,760, Level: 12 Points: 2,760, Level: 12 Points: 2,760, Level: 12
Thanks: Gave 37, Got 7
cheers looking to do similar
