3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Components > Interconnects, Speaker Cables and Switches
Latest AVForums Movie Reviews
Last King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray Review
Vengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray ReviewJulie & Julia Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Panasonic SC-BT200EB Home Cinema thosru All-in-one Systems 124 24-02-2010 6:42 PM
HD Elvis' Home Cinema Project HD Elvis Members' Home Cinema Gallery 35 27-01-2010 12:47 PM
Home plug & Xbox 360 question Des-mond Networking and NAS 9 15-11-2009 8:35 PM
JBL or Infinity home speakers? Blair387 Speakers 0 15-11-2009 7:39 PM
Old 15-11-2009, 8:54 PM   #1 (permalink)
Thanks: Gave 9, Got 1
home cinema cable
Hi all
can someone tell me will this kind of cable be ok 2 x 1.5mm² for 5.1 home cinema and will banana plugs fit ok.
Speaker cables, banana and spade plugs, connectors and adaptors.
wilki is offline   Reply With Quote
Old 17-11-2009, 7:20 AM   #2 (permalink)
Thanks: Gave 23, Got 56
Re: home cinema cable
yes it will however i would use 2.5mm - search previous threads
and yes banana plugs will fit
mrbenn is offline   Reply With Quote
wilki (19-11-2009)
Old 17-11-2009, 6:09 PM   #3 (permalink)
thanks for that i have searched but with no luck any chance you can point me
in the right direction as wot to by and where
thanks
Old 19-11-2009, 7:43 AM   #4 (permalink)
take a look at this and search through previous threads for vandamme blue
its £2 per m - or you can get it on a 100m roll from rapid electronics amongst others:
Van Damme Studio Grade Blue Speaker Cable 2.5mm - Speaker Cable - Audiovisual Online - High Quality Audio Video Cables and Accessories
this is what i and many on this forum use - its very good cable
if you want to spend a little less this fisual cable also looks very good (i havent used it)
Fisual Super Pearl 2.5mm Speaker Cable - Black - Speaker Cable - Audiovisual Online - High Quality Audio Video Cables and Accessories
and use these plugs
Fisual Easy Fix Banana Plugs - 4 Pack - Banana Plugs, Spades and Pins - Audiovisual Online - High Quality Audio Video Cables and Accessories
personally i only use the plug at the amp end for ease and to hopefully prevent shorting - just bare wire at the other - use a bit of contact cleaner (spray can from maplin) couple of times a year
wilki (19-11-2009)
Old 19-11-2009, 7:10 PM   #5 (permalink)
Thanks: Gave 0, Got 23
Hi wilki,
Ive just bought on 14th Van Damme 2x2.5 UPOFC Studio Grade Blue Speaker Game for £1.94 per metre from clearly av good service and 6 pence cheaper. They have lots of other stuff as well.
Penny saved here and there.
Hope this helps.
Waterhorse is offline   Reply With Quote
calbe, cinema, home
Copyright © 2000-2010 M2N E. & O. E.
