good flat silver speaker cable pse
Old 11-06-2009, 9:16 PM   #1
Thanks: Gave 30, Got 17
hi
any recommendation for under a wooden floor to two floor standing speakers ?
3.5 meters and 6 meters, silver and around 2.5 thickness.
thanks
Brenda
Old 12-06-2009, 10:24 AM   #2
Illustrious Mumbler
Mr Incredible's Avatar
19,521, Level: 33
Points: 19,521, Level: 33 Points: 19,521, Level: 33 Points: 19,521, Level: 33
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 1,660, Got 3,440
Re: good flat silver speaker cable pse
Out of interest, why silver?
IXOS do a flat cable, but not silver.
Old 12-06-2009, 1:36 PM   #3
hi
silvers better is it not ?
Brenda
Old 12-06-2009, 4:15 PM   #4
Illustrious Mumbler
19,521, Level: 33
Activity: 7.1%
From a sound quality perspective, no. From corrosion resistance, yes. So unless you plan on immersing your cables in salt water, copper is fine.
Old 12-06-2009, 4:32 PM   #5
Its to go under a wooden floor for many many years so i just want some good flat ones that will last as i cant rip up the floor and the speakers im getting are expensive.
Any suggestions welcome.
Brenda
Old 12-06-2009, 10:13 PM   #6
Illustrious Mumbler
19,521, Level: 33
Activity: 7.1%
Take your choice:
Ixos XHS133 Super Flat Speaker Cable - Speaker Cable - Audiovisual Online - High Quality Audio Video Cables and Accessories
Get copper and with the money you save buy yourself some CDs or DVD's!
Old 12-06-2009, 10:24 PM   #7
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,177
I use Ixos 233 flat and it about as thick as you can go under a carpet. Anything thicker and it will stick out and become a trip hazard. If you do want thicker cable, I would recommend the Van Damme Hifi 2.5mm and run it around the outside of the room behind the carpet gripper/under the skirting. It is certainly too thick to run under the carpet. I have several feet of the stuff, which I intend running at some point but other projects have taken precedence.
Old 13-06-2009, 8:31 AM   #8
Thanks mr terrible,
I will look into those, and dave its a wooden floor if thats makes any difference ?
Wont a silver cable be better then, as the speakers cable inside their cabinets are silver aswell ?
Also i suppose having a flat cable is why you dont get the thickness ie at least 2mm ?
thanks
Brenda
