Tv cable
Old 11-06-2009, 8:01 AM   #1
lagigolo's Avatar
2,177, Level: 10
Points: 2,177, Level: 10 Points: 2,177, Level: 10 Points: 2,177, Level: 10
Thanks: Gave 13, Got 3
Tv cable
Currently running cat 5 around the house and would like a tv socket in the kitchen. Instead of running normal coax, to futureproof could i run cat 5 between the 2 rooms and use blackbox video baluns IC440a between them?
Video-Only Balun - IC440A - Shop now - Black Box
Old 12-06-2009, 7:42 AM   #2
Assured Advertiser
Joe Fernand's Avatar
36,531, Level: 46
Points: 36,531, Level: 46 Points: 36,531, Level: 46 Points: 36,531, Level: 46
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 205, Got 1,344
Re: Tv cable
As long as your happy viewing in silence it will work fine
To future proof your home your best bet is to install lots of conduit that allows you to easily pull through any new cables as and when required.
If you want to pre wire I'd suggest you run an RF plus a CAT5 network - use multiple CAT5 if you want a Data network plus a network of twisted pair cables to carry video and audio signals using appropriate Balun.
Joe
