Scart length
Old 04-06-2009, 4:14 PM   #1
1,244, Level: 7
Points: 1,244, Level: 7 Points: 1,244, Level: 7 Points: 1,244, Level: 7
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Thanks: Gave 11, Got 0
Scart length
Apologies if this somewhere else on the forum, I had a quick scan but couldn't see it. I was basically wondering if a short difference in the length of a scart made much difference to signal quality.
I've seen a 3m on a good deal but only really need a couple of 1.5m, they're from a sky+ box and a dvd player to a panny plasma. Would I be better paying twice as much for the 1.5m (not on a deal) or will there be little difference if any if I go for the 3m??
Old 04-06-2009, 5:29 PM   #2
29,433, Level: 41
Points: 29,433, Level: 41 Points: 29,433, Level: 41 Points: 29,433, Level: 41
Activity: 39.9%
Activity: 39.9% Activity: 39.9% Activity: 39.9%
Thanks: Gave 175, Got 1,422
Re: Scart length
As long as the scart cables are of reasonable quality I very much doubt you would spot much (if any) difference between a 3m or 1.5m lead, as long as it isn't wrapped around power cables that is!
Mark.
hkrdan (04-06-2009)
