20-09-2006, 7:49 PM
#1 (permalink)
Thanks: Gave 2, Got 0
Best AV Receiver on richersounds for under £300?
My first post on this forum helped me choose the DVD player I want. Now it's time for the receiver...
I'm going to richersounds on Friday, though I could buy online or second-hand if necessary. Top price of £300 but I'd really prefer it to be under £250. Until recently they had a Denon AVR1706 on for £200. I still might try for one of those. Required specs?:
*I've decided on the Samsung DVDHD950 so the audio needs to be connectable to that. (I haven't chosen speakers yet)
*I want Pro Logic II as I'll be forcing a lot of stereo into 5.1. I guess I don't need IIx if I only have 5.1. I think I'll also need DTS.
*As well as the Samsung, I have a Mac Pro that I want hooked up. That's also DVI but the video from that and the DVD player don't need to go through the receiver do they? I could buy a manual switcher if necessary.
*Other than that, I don't really know anything. I just want it to sound good.
Any suggestions? Here's Richer Sounds' range. Thanks a lot!
20-09-2006, 8:39 PM
#2 (permalink)
Thanks: Gave 0, Got 14
Re: Best AV Receiver on richersounds for under £300?
I know its over budget but i recently bought the pioneer vsx1016 from richersounds for £384, well worth and a real steal at that price. I price matched it with digital direct.co.uk
20-09-2006, 11:11 PM
#3 (permalink)
Thanks: Gave 15, Got 44
How about the CA Azur 540R for £200 for the first model or £260 for the V2 model? Has got lots of good reviews for both HT and stereo performance and doesn't come bundled with all the unecessary HT fluff.
Regards,
DG
21-09-2006, 6:35 AM
#4 (permalink)
Thanks: Gave 0, Got 52
Regards,
DG
Amen
HT: CA 540R, 2 x Flying Mole Monoblocs(Driving Fronts), CA DVD-79, LG RH1999H DVD Recorder, Mordaunt-Short 908, 905C, 903S, 309W, Samsung 80cm LCD TV, DIY Cat5 speakers cables, DIY RG59(Adler Kabel) interconnects,Sennheiser HD555, Stereo: NAD320BEE, Marantz CD5001 CDP, Magneplanar SMGa's
21-09-2006, 8:04 AM
#5 (permalink)
Thanks: Gave 4, Got 58
Richer Sounds are really good on price matching so whatever you decide on make sure you do a bit of research to get the lowest price. As you are looking for something for £300 they'll beat the price by £10.
If you're using stereo sources a lot it IS worth looking out for Prologic IIx. Prologic IIx also adds different listening modes for music,games or movies.
http://www.dolby.com/consumer/techno...logic_IIx.html
LG 42PC1DA, Yamaha DSP757SE, MA Radius, REL Strata, Pioneer DVD696, Xbox 360, PS2, ipod Mini
21-09-2006, 8:49 AM
#6 (permalink)
Thanks: Gave 235, Got 279
From what I've picked up on the forums, the Cambridge Audio Azurs are supposed to be excellent for the price. Many happy owners on here.
Personally, I haven't used one myself, just going by many opnions I've seen etc.
Best of luck and btw, you won't be able to buy Cambridge Audio from anywhere but Richer Sounds, so if you decide on it, don't worry about trying to find pricematch details as you'd come up against a brick wall
Best of luck.
Dan.
> My main setup: Here - AVR280/DV89/MA RS/Samsung 32" LCD/Media PC: 3.0Ghz Core2Duo/4Gb/RAID0, GTX260 896Mb,
> My other setup: AVR250/IQ1/DC7100 SFF PC heavily upgraded.
> My opinions are mine and not those of avforums.
21-09-2006, 1:12 PM
#7 (permalink)
Thanks: Gave 21, Got 12
Originally Posted by limegreenzx
I second that. Different DSP modes for stereo are nice but I always listen to music on Prologic IIx.
22-09-2006, 9:07 AM
#8 (permalink)
Heathen  Listen to the source the way it was intended
Just joking, its different strokes for different folks. I prefer to listen to music in stereo mode and on a good recording(and proper setup) the soundfield is so wide that it almost become surround sound
22-09-2006, 10:43 AM
#9 (permalink)
Thanks: Gave 7, Got 5
agreed - I tried CD's using PLII and it just sounds weird! - 2 speakers for me
22-09-2006, 12:00 PM
#10 (permalink)
Your assuming stereo source means that the source was meant to be listened to in straight stereo. A lot of games and television shows have various Dolby Surround encoding. Having Dolby Prologic IIx as an option allows you to customise the steering better.
So listening with Dolby Prologic is the way it was intended to be listened to.
Got to agree with you that for music straight stereo is still the best.
22-09-2006, 2:01 PM
#11 (permalink)
Thanks: Gave 4, Got 7
Agreed on some points I originally used the 540r as a music amp but totally changed the sound of my system when I returned to a dedicated stereo amp. The 540r is a great surround receiver for films and probably gaming as well (although I don't personally) - just don't expect 'proper' hifi stereo performance. And don't bother with Dolby PLII for music, the processing in the amp renders it useless. Stick to stereo.
FOR MOVIES: Panasonic TH37-PX70, Toshiba HD-E1, Cambridge 540r v2, Humax PVR-8000T, Mordaunt-Short fronts/centre, Eltax rears, REL sub
FOR MUSIC: Cambridge Audio 640c CD, Cambridge Audio 840a, B&W CM1s, Pure Evoke-1 DABs (3!), Sony HD-NW5 & Sennheiser Headphones
